Question about Canon PowerShot A75 Digital Camera
Camera does not want to stay on
When turning on the camera (i739) the lens will come out like it wants to be ready to take a picture and then it will go back down and turn off by itself. I bought a memory card for it and it seems like it happened after I inserted into the camera because it was working fine before that. Was I supposed to do something before inserting the memory card? Any help I can get will be appreciated.
Thanks
    Master:
  • 383 Answers
Remove the memory card and try again .....
Posted on Mar 06, 2009
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
My camera will turn on then go off and the lens will not go out how do i fix this?
The manual is a bit confusing. I do have a power shot, but is is a bit younger. My camera does have 2 On buttons. One to put it in shooting mode. And one to set it in display mode. If I press the display button (arrow right) the lens stays where it is and I only can see pictures I took. When I press the on off button the lens comes out.
I think you only have to switch the main dial to the camera logo (shooting Mode) and then press the Disp button, to shoot pictures and if you want to view pictures, you turn the dial to playback Mode (arrow to the right) and press the Disp button.
If it works, no fix, just knowledge about how the camera works. It is all in the manual.
Jan 14, 2014 | Canon PowerShot A520 Digital Camera
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
The lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 27, 2010 | Canon PowerShot A540 Digital Camera
Polaroid i739 turns on then off
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries,or the camera may have a problem that requires professional repair.
Jan 11, 2010 | Polaroid I739M Digital Camera
The Same problem
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 05, 2009 | Kodak EasyShare M1033 Digital Camera
I have a kodak m1033 turns on then shuts right off
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
Camera does not show picture after shooting
What exactly is a 'typ' camera ? Have you set instant review in the menu system ?
May 11, 2017 | Polaroid I739M Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
