Question about Whirlpool Gold Black-on-Black 25.4 cu. ft. Side-By-Side Refrigerator w / Accu-Chill Temperature Control System GD5SHGXLB
Buzzing whirlpool When I went to use my microwave it started buzzing really loud. Is there anything I can do to be able to keep my microwave? Its a large whirlpool gold 1100 watt 1.8 or 1.9 cubic in. Any advise would be appreciated.
  • btraitz Mar 06, 2009
    I HAVE THE SAME PROBLEM STARTING THERE IS A BUZZING SOUND COMING FROM UNIT WHEN YOU ARE IN COOK MODE . i WONDER IF THIS IS THE MAGNETRON STARTING TO GO OUT . AND WHIRLPOOL DOESNT COVER IT AFTER A COUPLE OF YEARS AND YOU WOULD NEED A SERVICE CALL FIRST TO VERIFY AND THEN ORDER PART AND THEN PAY TO HAVE IT PUT IN . wHAT A RACKET THEY HAVE. SURE HOPE THE SPACE STATION DOESNT USE WHIRLPOOL APPLIANCES.
  • 400 Answers
The buzzing sound can be coming from the magnetron. There may be an insect which has gained access and is being nuked. Or the magnetron may need to be replaced. Not an expensive repair.
Posted on Mar 06, 2009
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My microwave no longer heats anything and also makes a really loud buzzing sound when i attempt to use it.
The problem is most likely caused by a defective magnetron that "heats the food" is loading down the high voltage transformer causing it to make a loud buzzing sound. The cost to repair (depending on make and model) will probably approach the cost of a new microwave oven when you factor parts and labor.
Jan 23, 2011 | Microwave Ovens
There is power but it is not heating anything and after about 10 seconds it makes a very loud noise.
If it's making a loud buzzing like sound it's the component that sends waves through the microwave. This piece is about $120 plus they charge about $65+ to install it. Also some charge the diagnostic fee of about $75. Either way, once a microwave goes out it's pretty much useless to repair one unless you have put a lot of money into it. We had ours to do the exact thing you describe and it was cheaper to buy another and me install it basically because I was getting another 2 year warranty as to the other had run out.
Jun 27, 2010 | Whirlpool GT4175SPS Stainless Steel 1200...
My microwave magnets keep cracking
Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
Feb 04, 2010 | Kenmore 62622 Microwave Oven
Arcing and noise when turn it on
I cleaned the microwave really well. I used a screwdriver to pull the plastic cover out enough to clean behind the edges with a soft toothbrush. Seems to have corrected the problem.
Oct 15, 2009 | Whirlpool MT4155SP Microwave Oven
Whirlpool microwave makes loud buzzing noise
When your microwave oven won't cook your food, and, you hear a loud buzzing sound, it’s normally caused by a faulty (a) diode (b) high-voltage capacitor (b) magnetron.
The diode would be the most likely culprit of the three components. It’s also by far the cheapest!
Sep 21, 2009 | Whirlpool MH6140XK Microwave Oven
Microwave Buzzing When Not in Use
Are you using a 3 pronged outlet and is it grounded? If you have a 2 holed outlet and are using a ground eliminator adapter, try turning the plug around to reverse the polarity. If this helps, then it would be advisable to have an electrician to ground your oven.
May 22, 2008 | Whirlpool MH7140XF Microwave Oven
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Refrigerators Logo
221 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
