I can plug in to other inputs and select them, they all work fine.
SOURCE: VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
SOURCE: pioneer vsx d608-no sound
this is an IC failing , it changes the pre amplified audio to the amp.but there is most likely something causing this failure as well ,to much voltage to the chip , it will need testing
SOURCE: pioneer vsx-515 no sound from dvd player plugged
Its just a wire covered with a shield. You can ohm it out with a multimeter.
SOURCE: pioneer vsx-d810s only dvd 7.1 input works and
Try resetting the receiver the Pioneer Web site should have the reset procedure for your model if that doesn't work time to send to the shop.
