Question about Tascam CC-222mkIII CD Player / Recorder
Trying to Record to CD-RW, but appear Disk Error when record
I'm trying to record voice from mic to Blank CD-RW, but when i insert it, the display show "disk error", and i try to go through record button, and the lcd show "Disc Full". I'm using the blank CD-RW, but it show Disc Full, disc error, why?
Please Help
My Cd Player : Tascam cc-222
  • Anonymous Mar 19, 2014
    I recently bought two Tascams, a CD-RW700 and a CD-RW750, from the widow of a recently deceased engineer, Neither of the are working - one shows Welcome but does nothing else, and the other will try to read a disc for long minutes and give me a disc error. Where can I take them locally for checking out?
  • 71 Answers
Its the laser driver / lens its shot not cheap to fix
Posted on Aug 25, 2010
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
My denon c550r won't record (unit is set on duel, input is coax, using correct disk) I press record the display appears as if going to record but it switches back to "blank disk"
first off, if machine is set to dual, then its trying to record from the other disc side. You need to have it set to your coax input. Also if your trying to copy a disc, not all of them allow that option. If this doesnt help, go to MusiciansBuy.com. Can get help with any audio componants there
Mar 04, 2011 | Denon DN-C550R 2-Disc CD Recorder
I'm trying to record a DVD on the DVD/CD-RW combo recorder in my Acer Aspire laptop. When I insert a blank DVD, whether it's a R or a -R, I just keep getting the message to insert a blank DVD. How do I...
Try a different manufacturer/brand of DVD-recordable disks.
If you still have the problem, then your drive is malfunctioning,
and you need to get a qualified technician to disassemble your computer, and replace it.
Oct 09, 2010 | Acer Aspire One PC Notebook
CD/DVD will not burn DVD
Did you tell CDBurnerXP that you want to burn a CD? or to burn a DVD?
Does this happen with _EVERY_ "blank" disk that you insert, or just one disk?
Can your DVD-RW _read_ a previously-recorded CD? DVD?
If not, then that hardware is suspect.
Sep 14, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
DVD ROM/CD-RW Drive
try to roll back the driver , if that doesn't work go to the manufactures web site and download the driver . if it still doesn't record install the drive in another computer and if it doesn't work then it maybe a bad drive itself
Aug 06, 2008 | Gateway 310S (2900621) PC Desktop
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Tascam CC-222mkIII CD Player / Recorder Logo
590 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
