Question about Toshiba Satellite M35X-S349 Notebook
M35X-S349 no video no post
This laptop started freezing and we thought it may be hardware problem. Tested memory and hard drive and both passed. Tried to restore and gave blue screen error. Turned off and tried to turn on.
Now I do not get any video. No post. Turns on, all lights on, fan spins for few seconds but never any video. Seems like alot of people have same issue but no solution. It IS NOT a powerjack problem. Jack not loose and lights stay on when plugged in. Please help.
This is what done so far:
Tried to remove battery and reset power settings
Tried without battery, just ac, just battery.
Tried with single memory chip(has two) in each slot, changed them up.
Used compressed air to blow out fan.
Checked connection to board with LCD. Reseated and snug.
Pulled hard drive and formatted.
Strange. Was working fine(except for freezing) before tried to restore.
Please help.
Thanks!
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
Turn on screen is black windows will not come up
If screen is totally off (black because of it's off) - screen is dead. If it's black, but you see it's working - could be hard drive or memory fail.
Mar 14, 2011 | Toshiba Satellite M35X-S349 Notebook
Satellite M35X-S349 PC Notebook: How do I speed up my toshiba pg 35 laptop...
RegTOOL can helps you scan your PC, safely clean the errors & invalid entries cause system slow, freezing and crashing, and repair registry problems to speedup your computer performances. It is easy to use.
http://www.keep-pc-clean.com/
May 18, 2010 | Toshiba Satellite M35X-S349 Notebook
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
Stuck in safe mode and can't get to reboot
either the hard drive has failed or you are experiencing software corruption of your windows files.run the recovery or if you need information from that drive get a new hard drive install it run the recovery and use an external usb ide-sata converter to transfer your files
Nov 04, 2009 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite Laptop M35X-S167 - Windows Won't Start
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Jul 19, 2009 | Toshiba Satellite M35X-S349 Notebook
Toshiba m35x s149
Hey i just read your post and i have the same proble with my laptop did you find any solution for the problem
Sep 13, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba M35X-S349 (Freezes Periodically)
Update: I looked at the plug connecting the HD to the PC and pulled it about 1/2 way back off and reinserted into machine. I then pulled the HD back out and noticed that it was not all the way pushed back on and it wasnt parallel to the HD. Basically I am thinking that the HD is not sitting properly in the bay for some reason or another, but I have been running 10+ hours with no problems as of yet. I did reformat the HD so I am going down that road of reloading and letting run awhile, reboot, repeat. Not sure if solution, but looking real good at this point.
Aug 11, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite M35X-S349 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
