Question about Intuit QuickBooks® Pro 2007 Full Version for Mac
Greetings. Running QB Pro 2007 for Mac. When opening company file, a duplicate file is somehow created and now I have my two bookkeepers' work amongst too many files. How did this happen and how to fix???
    Sergeant:
    Champion:
  • 315 Answers
Delete your existing sync depot and create a new one. Then create a new blank customer manager database on each users computer and then sync them to the new depot. That will make the file duplication stop.
Posted on Mar 06, 2009
  • 1,800 Answers
Check for a Virus ifluence.
by giving a scan u will get rid of any kind of viruses
download avira as a free and effective antivirus.
Issue archiving data during upgrade to QB Pro 2007
Don't worry about the sales receipts. You have a bigger problem at hand. The reason it is bringing up pieces of old data is because you are nearing your limits in the program. There is a a limit in lists in QBooks (Customer names, vendor names, employee names, other names add them all up together) that when you get close to exceeding it the program starts to randomly purge data. It does things like deletes some things on an old deposit, or deletes some of the invoices already paid for by a payment posted and sometimes it deletes the customers main information (address ect.). When it randomly purges transactions that are linked with others then the records begin to error out. This will continue until the program stops loading and locks up completely. There are many ways to solve the problem. Some people keep one year of accounting records in each company file and begin a new file with the new year. You can consolidate names (go through your inactive entries on all lists and see if there are duplicates you can merge). I would try and clean up as many as possible by consolidating and merging and then use the verify data feature under file and then utiltiies and follow the instructions to very the integrity of your file. If it passes then you can try and archive previous periods again.
Jul 22, 2010 | Intuit QuickBooks Pro 2007 Full Version...
Reinstall QuickBook Pro 2008 after clean reinstall of XP Pro SP3
Once you reinstall Quickbooks, you should be able to copy your QB files to the My Documents folder then open that file in quickbooks
Mar 25, 2010 | Dell Latitude D830 Laptop Computer PC...
Quickbooks Pro 2007 has stopped working. when i
uninstall the software 100% reboot the machine so the information obtained in ram is not going to interfere with new installation. using your original cdrom that came with the kit, install your quick books 2007 software register it with the original code and product id sequence numbers. when it tries to run theirs 3 things happening now. the program in initializing it;s visual c run time libraries. and well as calling the dynamically loaded libraries from the windows directory and other locations. if a program was removed that used these files and it was uninstalled with the files then it is possible you will have to install qb from scratch and use the qbw or quick books workspace file to run your company files afterwords. backup the qbw files encase of problems. this is often tell take sings of viral or system melware. then scan with your virus software. and see if anything was crashing the program. other options involve system files missing that are used. good luck.
Sep 20, 2009 | Intuit QuickBooks Pro 2008: Windows
After pc crash, transferring qb pro 2007 to new pc
once you install intuit on your new pc or new harddrive open the program. insert the dvd disc. go to wherever you open files. select the drive with the dvd instead of the C drive. you should see the files. click on one and the program should open it. the program doesn't care if the files are on the C drive, D drive or U drive. it just needs a file with the right format and file extension.
Jun 23, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks Premier 2008 will not open quickbooks 2008 Pro files. What's up?
PLEASE REMEMBER THERE SHOULD NOT BE ANY PROBLEM IN OPENING A QB PRO 2008 COMPANY FILE IN PREMIER 2008. THERE SHOULD BE SOME OTHER REASON TO IT .
If you need the resolution, please reply with the foll :
1. Which Windows Version you have . Is it Win XP or Vista or 7?
2. How do you try to open the company file ? Please list the steps .
3. Do you get any erro msg ?
4. Does QB crash?
5. Do you have a backup company file QBB or main company file QBW ?
Please try these steps or reply to my questions:
1. Change the location of the company file.
2. Disable UAC.
2. Rename the company file .
3. Delete the ND and TLG file .
Apr 24, 2009 | Intuit QuickBooks Pro 2008: Windows
My QB crashes everytime I try to invoice...only with one company, but with others it runs fine. Problem is i need the giles from that one company, What do I do?
You should verify your data file (Click on file, click on utilities, click on verify data) If quickbooks doesn't find any problems, Back up your company to a different location and if your using 2006 or higher, create a portable file, close quickbooks, reopen quickbooks, and then click on open portable. When it prompts you to backup, click ok and back up again using a different file name.
You then need to go to templates, and (sorry to tell you this ) change each one to the default setting (click on lists, click on templates, the click on templates at the bottom, and click on edit, click on additional customization and then default. Then click save and close. Do this for all templates.
Also resort each list (item customer and vendor) to their original order.
Close the file and then reopen and verify data - if this doesn't fix the problem you will need to contact a pro advisor or intuit for aid in fixing the file
Jan 30, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbook will open but will not bring anything up
Hold Ctrl key and click on QB icon.
Also Alt+F4 may work
Jan 23, 2009 | Intuit QuickBooks: Pro 2005 for PC
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Jan 21, 2009 | Intuit QuickBooks Premier: Accountant...
Bank reconciliation locking up, printing locking up.
In your list of printers, you will have one installed by QB called "QuickBooks PDF Converter". Do your reconcile and when it seems to lock up, open your list of printers from the control panel and open this QB printer. There will be a document waiting to print (not sure why, it might be internal to QB). Select that document and hit the delete key. That should free QB up to continue (works for me). You may need to select it and press Delete two different times to actually remove it from the printer. Finally, because it is not easy to open up Printers every time, make a shortcut on your quick launch or desktop to the Printers applet.
Dec 11, 2008 | Intuit QuickBooks Pro 2008: Windows
Intuit QuickBooks® Pro 2007 Full Version for Mac Logo
96 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
