Question about Microsoft Windows XP Home Edition
WMI Has encountered a problem and needs to close
Get pop up that says WMI has to close. How do I resolve this issue?
  • 304 Answers
Symptom
When you attempt to start the Windows Management Instrumentation (WMI) service, you may receive the following error message, and the service does not start:
Could not start the windows management instrumentation service on local computer.
Error 1068: The dependency service or group failed to start
Resolution
First, verify the number of dependencies attached to the WMI service. This can be viewed by running the following command from Start, Run:
CMD /K SC QC WINMGMT
The output should exactly as given below.
[SC] GetServiceConfig SUCCESS
SERVICE_NAME: winmgmt
TYPE : 20 WIN32_SHARE_PROCESS
START_TYPE : 2 AUTO_START
ERROR_CONTROL : 0 IGNORE
BINARY_PATH_NAME : C:\WINDOWS\system32\svchost.exe -k netsvcs
LOAD_ORDER_GROUP :
TAG : 0
DISPLAY_NAME : Windows Management Instrumentation
DEPENDENCIES : RPCSS
SERVICE_START_NAME : LocalSystem
*See attachment*
The only dependency is the RPCSS service, and it does run by default whenever you start Windows. If you have any other dependencies listed, then it may be the causing the problem. To remove the additional Dependencies, follow this:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Before you modify the registry, backup the registry key by exporting the corresponding branch. Also, see here to learn how to perform a complete registry backup.
Click Start, Run and type Regedit.exe
Navigate to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\winmgmt
Double-click DependOnService, and set it's Value data to RPCSS
Close Regedit and restart Windows
If this fails, you will need to do a repair installation..
Hope this will be helpfull
Thanks & Regards
NANDU
Posted on Mar 06, 2009
Outlook has encountered a problem
Below a link with information that may help you resolve this issue:
https://outlook.recoverytoolbox.com/
May 24, 2017 | Computers & Internet
WMI has encountered a problem and needs to close. We are sorry for the inconvenience.
This is not unusual, Sometimes the software encounters a order that it cannot follow and looks into its error data and sends this message. It maybe a problem downloading an update from Windows, it could be a virus encounter, it could be malware ( Advertisers hijacking your desktop). If it occurs often, then you need to clean somethings out. See: http://social.answers.microsoft.com/Forums/en-US/xpperformance/thread/bb4e514d-9afc-41ba-b926-366d2da5e65e
Dec 07, 2010 | Microsoft Windows XP Home Edition for PC
DEP/WMI problem
WMI is a part of Windows that allows other remote computers to control your own. This means that someone has infected your pc with a rootkit that has taken partial control of it. Good rootkits are virtually undetectable and practically impossible to remove. Recover all your files and do a full reinstall - when , during install, you will be asked what type of format do you want select full , not quick.
Jul 09, 2010 | Microsoft Windows XP Home Edition
Google earth keeps encountering a problem and needs to close. I've removed and reinstalled this programme twice and it keeps coming up with this same fault.
You may be a victim of spyware/maleware infections. You will need to have your system cleaned. This should help resolve your issue.
I would recommend trying CCleaner first to see if this helps you.
Please keep me posted and updated on your issue. I am here for you and will see your issues out till resolved.
Have a great and wonderful day :)
Thank You
Please do not hesitate to contact support :)
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com
http://www.itsupport.co.cc
May 20, 2010 | Computers & Internet
Repairing windows (wmi) on windows xp ser. pk. 3 not wanting to replace the os in the process.Restoring to an earlier date isn't working, says its unable to restore to that date.But, anyway finding that...
Microsoft has released a new diagnosis tool that helps system administrators diagnose and repair problems with the WMI. It is advisable to go through the WMIDiag_ReadMe.doc file to understand how the utility works, and the supported command-line arguments. Here is the download link: The WMI Diagnosis Utility
You may use the utility (WMIDiag.vbs) to find if a repository rebuild is necessary or not. The utility runs a comprehensive testing of WMI and reports the results to a log file, which is placed in the user's Temp folder (%Temp%) folder by default.
Mr. Alain Lissoir [MS] was kind enough to share the following info with me:
If there is a need among all problems detected by WMIDiag to rebuild the repository after attempting all fix suggested by WMIDiag, WMIDiag will list the rebuild of the repository as the last action among thing that can be done (before rebuilding the repository).
Here are some of the useful links that I came across from Alain's homepage:
Mar 24, 2010 | Microsoft Windows XP Professional With...
''WMI Provider Host stopped working'' keeps popping up. Very annoying! No one can give a workable solution including Micro Soft.
Is that on Vista, XP, or other?
On Vista that may be a known issue and there is a fix available (ask for KB935553).
The problem has also arisen in conjunction with several third party programs; try temporarily disabling or terminating them one at a time and see whether you can pinpoint any one of them which might be responsible.
You might try disabling the WMI provider altogether, and check what services and applications are affected. To do so, run the "services.msc" utility and locate the WMI entry, then stop it. If it works and no ill effects are apparent, consider setting startup of WMI to "manual" or "disabled".
Oct 22, 2009 | HP Computers & Internet
DEP comes on and closes WMI which does not allow acess to IE. I set boot.ini to /execute=AlwaysOff and rebooted, but same problem.
If you have done any updates on your computer and you upgraded your browser to Internet Explorer 8, then you need to do this to correct your issue (I have the same problem today for a clients computer and this resolved it):
In Internet Explorer 8 goto to Tools > Internet Options > Click on Advanced Tab > go under Security and uncheck "Enable memory protection to help mitigate online attacks"
This should fix you up, and if it doesn't let me know. I know all about DEP.
Mar 08, 2009 | Dell Vostro 1500 Notebook
When I try to download something from a website, all of my windows close before I can accept the download
- If you were force to upgrade your windows to vista, I thinks some of the drive are realy compatible on your system.
- You may want to run windows update service pack 1 , It might help you resolved some of the issue.
-Give me more some details of your issue (error-pop-ups, bluescreen)
Oct 11, 2008 | Microsoft Windows Vista Ultimate Edition
Internet explorer has encountered a problen and needs to close. It offers send report, don't send or debug. How do I get rid of this pop up?
Seems to be a problem with a plugin or a general browser issue. Try restarting the computer and see if this resolves the issue. If not, then you may have to reinstall IE.
Jun 14, 2008 | HP Computers & Internet
Microsoft Windows XP Home Edition Logo
2,141 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
