Question about Video Game Consoles & Games
Wii system won't read disk - Video Game Consoles & Games
  • bob2329 Apr 15, 2009
    one day I was playin wii fit the changed the disk to tiger 09 and plated dat for an hour and then put wii fit back in and now it doesent read any of my games
  • 38 Answers
Try to buy one of those cds with brushes on it to try to clean the lens of your dvd drive. If that does not work maybe you should consider buying another dvd drive.
Posted on Mar 14, 2009
The wii console won't read the games?
there is what some people call an "eye" inside (it a sensor) inside that reads the disks SOMETIME this can get dirty and sometimes it can also break completely.... I would first start by getting a cleaning disk you can find them at most gaming stores you simply pop it in and it does all the work... they are also cheap so always the best place to start... If that does not work then you will need to have the sensor fixed...... SOMETIMES and this is NOT a fix but a sometimes useful temp fix you can hold the system upside down and then put the disc in and continue holding it that way until it loads that sometimes works`
Apr 16, 2013 | Video Game Consoles & Games
How to fix a wii that won' t read disks
Drive has failed contact Nintendo for repairs.
Jan 11, 2013 | Video Game Consoles & Games
My Wii will not Play GC games. It tells me "Unable to read disk, Check operations manual". Game has no scratches and my Wii is about 3years old. Plays Wii games just fine so I don't know...
Check your serial number on your Wii. If it starts with KU, it can't read them. If it starts with LU, and it's ONLY GC games it won't play, then your system needs to be repaired.
Out of warranty repair cost is $85 plus tax for America.
Jun 03, 2012 | Nintendo Wii Console
Won't read disc on Wii
try to get another copy of the disk or just try to clean it
Dec 25, 2011 | Nintendo Video Game Consoles & Games
Console won't read disk. when disk in console, message comes up unable to read disk
If you are getting that message then there is likely 2 reasons.
1: is because your disk is scratched up or something.
2: your disk reader that is inside of your Wii Console is out of place.
Oct 06, 2011 | Nintendo Wii Console
None of the games will load,it says ''disk cannot be read,go to wii manual for troubleshooting''. i dont have a manual.
I have had that same problem with a game of mine. I believe that something may have gotten on the disk. Try to clean the disk and then try again. If it still won't work, you probably need to replace it.
Aug 05, 2011 | Nintendo Wii Console
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Thanks for using Fixya.
Jan 28, 2011 | Video Game Consoles & Games
Wii wont read disk
mchlstull
In regards to your Wii not reading disks most likely your laser is dirty or you are having trouble with your drive its self.
They make a laser cleaning kit for the Wii you may try using to clean the laser. Note DO NOT USE a DVD/CD cleaner disk on the Wii. Only use ones that are made for game systems. Alot of times the lense for the laser is made different for game systems and if you use a standard one it can scratch the lense.
If this does not work then I would see if you are still in warranty. If you do then contact Wii support about getting an RMA.
If not you will need to look into replacing the drive. (There are several walk throughs on the Internet.) If you do not think you can do it your self then you may be able to find a local repair shop that can do it for you.
Hope this helps
Issken
Dec 27, 2009 | Nintendo Wii Console
The disk cant be read
try the disk on a different wii and load the saved file on memory card and try it from there.if the game works fine with another account then the account that your trying to load is corrupted.if the game does read on a different system then it is your wii.(doubt it but is possible)if the game doesn't work with a new account then it is the cd.
Jun 27, 2009 | D3 Publisher Dragon Blade: Wrath of Fire...
Cant read disk
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
170
Dec 26, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
443 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
