As agitator washes, tub spins faster and faster
As agitator washes, tub should go back and forth opposite agitator, but it moves clockwise faster and faster until water spins up and spills over side of tub :-(
    Brigadier General:
  • 4,669 Answers
It has a bad brake assembly.
Posted on Mar 06, 2009
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
I'm just a tentant asking a question before calling maintenance. Is the agitator suppose to only turn in one direction? I thought it was suppose to be a back and forth movement. This model is a...
You have a 2 part agitator.
The bottom portion moves back and forth. The upper corkscrew moves clockwise only,pulling the laundry down and around the tub.
Jul 21, 2011 | Estate ETW4400VQ Top Load Washer
Spin cycle works fine but when on wash cycle the tub wont move
A top-load washing machine is not supposed to move the tub on wash cycle, but the agitator in the center is supposed to rotate back and forth. If that isn't happening, there is a problem with the clutch or the transmission.
Jan 26, 2011 | Kitchen Ranges
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Tub spins while during wash cycle
trust your memery it gos back wards as well
Oct 24, 2009 | Washing Machines
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
