I am looking for a model number on a Speed Queen Marathon washer
I am looking for a model number on a Speed Queen Marathon heavy duty top loading washer can someone help me? I need to find a belt for the washer. There is a number but i was told it wasn't the model number. that number is 31315 anyone have a marathon model number?
  • Anonymous Mar 31, 2014
    Belt size for speed queen washer model aws17nw
    President:
  • 1,294 Answers
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
  • prem mathew Mar 06, 2009
    oops, was for front loaders, anyway..................
The water flowing into my speed queen is vert slow
The to ensure that the water valves at the inlets are fully open. If they are, then shut them off and remove the hoses from the supply to the washer. There is usually a small metal screen-type filter in the connection at the back of the washer for each hose. These may be clogging up. They can be carefully removed, cleaned, and reinstalled.
Sep 08, 2016 | Speed Queen AWS52NW Top Load Washer
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Speed queen Marathon top loading washer- Water leaks into drum when not in use??? Shut off valves in the basement.
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
Mar 28, 2010 | Speed Queen AWS52NW Top Load Washer
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Feb 23, 2010 | Speed Queen AWS75NW Top Load Washer
What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Jun 29, 2009 | Speed Queen AWS52NW Top Load Washer
Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Washing Machines Logo
523 people viewed this question
Top Washing Machines Experts
