Question about D-Link Xtreme N DIR-655 Wireless Router
VPN drops when using a D-Link Dir655 router
I am using a D-link Dir655 router. When I launch the VPN behind the router it does connect for usually less than 2 minutes. The Log says PPTP ALG rejected packet from the IP of the server I am connectin the VPN tunnel to. When I setup a Linksys router I have no problems. Am I making a setup error?
Thanks .
  • mariusg Apr 10, 2009
    I have the same problem! I am not able to connect with VPN at all, it hangs on the "Verifying username and password" and eventually times out with an Error 721: The remote computer did not respond.
    I have even tried to put my PC in the DMZ, but this does not work either. I have seen a lot of other suggested fixes for this problem out there (like using a virtual server suggested here: http://www.dslreports.com/forum/remark,1...) but no one fixes my problem.
    To make it work I have to connect the computer directly to my Cabel modem. This of cource meens that all the other computers in my house is offline every time I have to connect to my ofice using VPN.
    Any one out there that has found a solution to this problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Posted on Mar 08, 2009
Watch netflix with samsung TV
Hi , It is easy to have bbc iplayer or UK or US netflix on Samsung smart TV and watch it outside the UK or US
there are two way to do , one is using DNS ,, but no recommended because it blocked occasionally, so the best way is use reliable VPN provider which you can get from this link http://www.overplay.net/#a_aid=vpnprovider
you can get the account and pay for one month 10 $ or one Year 100 $ VPN + smart DNS , also you can ask for refund if not work for you so you are in safe side!
after getting your account ready , you need VPN Router , and technology of VPN better should be openvpn it is faster more stable than pptp or l2tp because it reconnect if even your main connection drop and restored
once your VPN router is ready , just reset your samsung TV to factory default , you can go to TV manual and do it
connect your TV directly to the VPN Router for your reference connection should be like below
Main Internet Router -----> VPN Router ------> TV
restart your TV and live it for 30 minutes ! vola you will see netflix , Pandoora , Spotify will apear on TV apps , just enter your user name password of netflix and start enjoying it !!! let me know if this helps?
May 22, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
Verizon disconnects in minutes when on VPN
This is a common problem with VPN and by no means confined to Verizon. You will need to check with whoever you are VPN connecting to as it is most likely they that are experiencing a problem and dropping your connection. Contact the host Network Admin or Support team to assist you. I have had this happen many times, especially when travelling and it has never been an issue with my laptop and has always been the host.
Sep 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Want to make a network connection between two office 800 meters.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Mar 03, 2009 | D-Link (DIR-130) Router
VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Mar 02, 2009 | D-Link (DIR-130) Router
Avaya VPN phone behind a DIR-655
- Logon to the configuration page of the router
- Select Firewall Settings at the left side
- Uncheck the boxes under Application Gateway Level at the bottom part
- And Click on Save Settings at the top.
Jan 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
D-Link 624M unable to connect to VPN
unable to log into router user 192.168.0.1 d-lin 624m
Nov 17, 2008 | D-Link DI-624M Router (DI624MRE)
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
8,215 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
