Question about Hamilton Beach BrewStation 47224 Coffee Maker
The small plastic washer is warped on mine and causes it to leak
Think it is simpler just to buy a new model Brew Station. I'm tired of the messes it makes..
  • 14 Answers
I had the same problem only the small rubber gasket (looks like a hose washer) on mine fell out. I contacted the Hamilton Beach product support department and was tole the WHOLE TANE NEEDED TO BE REPLACED. BUT do not dispair. They are sending me a whole new tank for the cost of shipping only!!!! How's that for customer service. Shipping is only $5.00. Call Hamilton Beach ast 1-800-851-8900 and wait for instructions. In your case, if it's just "warped" they can tell you hopw to reinstall it. In my case, the part that holds it, a little ***** white plastic part with a star on top) broke off so for $5 bucks, I get a whole new tank! I love Hamilton Beach!!!!
klvillane
Posted on Jul 13, 2009
  • 408 Answers
You can buy just the part alon.  Search on goole or ebay.
Posted on Mar 06, 2009
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
The washer fluid is leaking out on my 2000 - BMW 328i
Hi Friend: Check your Window Washer Canister 1st.If its Not Leaking You'll Need to Check ALL your Hoses From The Washer Canister to the 2 Spray Nozzles . And also to Your Washere Pump.Or its Posible your Washer Pump its Self has Developed a Leak.More Than likely its a Hose thats Old and Cracked, Just Follow ALL Hoses from The Washer with your Hand and Eyes.Have Someone Get into the Vehicle After You Fill your Washer Resevoir and Have the Turn your Washer On To See if It Reveals your Leak,Hope this Helps You, Please Let Me Know.If its your Canister or Hoses there Not Expensive To Replace. From =d_hubbs
Jun 08, 2010 | 2000 BMW 3 Series
Dispenser not working
You don't say exactly what the problem is with your Brew Station but I know I bought the model 47214 and had to return it twice. It kept stopping and starting numerous times during the brew cycle. I retuned both to Walmart and they exchanged them with no receipt and no charge each time. I think I had 60 or 90 days to excahnge them. Anyway, the last one I took back was at the same time that the model 47665 was on sale. (the next better model) So I upgranded for the same price. I recently had a problem with the dispensing tank of my current Brew Station, model #47655. The coffee ran right thru onto the counter and floor. I called Hamilton Beach customer service at 1-800-851-8900 and explained the problem. They informed me that the little tiny plastic piece that held the small gasket (looks like a water hose gasket) in place had broken off and could not be fixed. I would need a whole new tank. My brew station is about 8 months old with no receipt. HB then informed me that the whole new tank could and would be sent to me for the cost of shipping of $5.00. YUP!!! FIVE DOLLARS gets me a whole new tank!!!!! I love Hamilton Beach. They truly do stand behind their products. Have your husband call them at 1-800-851-8900 and explain the problem. They will do everything possible to remedy the problem at nominal cost to you. Good Luck. Katherine
Jun 21, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Leaking
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
We have a hamilton beach brew station Model 47114 and have enjoyed it, but it leaks. We brew the coffee and return to a mess on the kitchen counter. I threw it in the garbage today, but fished it out...
I had the same problem with mine when it was brand new. I called Hamilton Beach and told them what the problem was and they sent me out the new parts to fix it. It was actually the rubber gasket that was causing mine to leak. Hope this helps.
Dec 26, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Dec 16, 2008 | Gaggia Titanium Espresso Machine
My Whirlpool Cabrio Washer keeps giving me the DL (Door unlocked code) even though I can look under the lid and see the latch extend out. I think the plastic to the glass lid has warped, keeping the...
try the lid switch/lock first ..press clips under edge each corner raise top 2 screws hole switch in place remove 3 screws along back of control panel lift console up and forward switch plugs into control bd on left side
Jul 08, 2008 | Whirlpool Washing Machines
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Hamilton Beach BrewStation 47224 Coffee Maker Logo
381 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
