Question about Philips Audio Players & Recorders
Buzzing noise coming from speakers in phillips mcd718 micro theatre after having installed insignia 52 plasma hdtv. Just happened about four hours ago.
    Novelist:
  • 91 Answers
Possibly a ground issue , do you have everything plugged into a line conditioning power strip? are your speaker wire,s plugged into the red and black speaker connectors propperly,and are the positive and negative wires in the right order? also check that the component or hdmi cables are not the issue , but usually the buzzing noise would sound more like a ground issue , I hope i was able to help you solve your issue if not feel free to contact me again so we can tackle this issue together , if i was able to help you pleace leave a nice review ,thanks alot ,Sincerely glenn mayer
Posted on Mar 07, 2009
Tip
Insignia NS-PDP50 Manual Download
Download Insignia NS-PDP50 Plasma HDTV Manual
Have you misplaced your Insignia NS-PDP50 Plasma HDTV Manual ?
Would you like a digital, searchable, pdf version of the Insignia NS-PDP50 Plasma HDTV Guide?
Follow this link (& click FREE) to download a pdf version of the Insignia NS-PDP50 Plasma HDTV documentation.
I hope that helps.
__________________________________
on May 08, 2010 | Insignia 50 in. Flat-Panel Plasma HDTV
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
The TV started marking a buzzing noise (seemed to be coming from the right speaker) and now the volume just stopped working. What do I do?
This problem would be an easy fix with a scope, but if you don't have a scope, first check the power going to the speaker-board with your volt meter, if the voltage is good then check the transistors, sound like a transistor problem.
Jan 27, 2011 | JVC HD-52G786 52" Rear Projection HDTV
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
Flemflam-   There is a couple of options here. If you are using a DirecTV Receiver or a box from the cable company then you want to run the Audio out lines to your Audio/Surround Sound Receiver. If you are running cable directly into the TV then you want to use the Audio Out Plugs on the TV. In some cases there is no Audio out but there is a Headphones out. In this case you can run a Mini-Plug to Composite Audio cable to the receiver.    You can also Call 1-800-GeekSquad and they will dispatch an Home Theater Installer to resolve your problem! They are great for Turn Key Solutions!
Jul 11, 2008 | Insignia LCDTV26 26 in. Television
Phillips plasma 50pf7320
I have a 50 inch phillips plasma and the pixtals are taking over and color is dark the amblight is very dim,
Jun 25, 2008 | Televison & Video
Speakers Make a Very Loud Noise that Increases
try uninstalling drivers and reinstall them.
also remove latest M.S update as some update cause more trouble than they are worth
May 21, 2008 | Audio Players & Recorders
Unwanted sound from subwoofer.
switch your subwoofer off from the socket for at least 30 minutes and check if the noise is still there,if its still there open it and play a movie then press it lower if the sound stops then you will have to put some toilet papers at the back of it ,thats what I did to mine.
Feb 19, 2008 | Logitech S200 Computer Speakers
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
232 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
