Question about Maytag EPIC MFW9700S Front Load Washer
My Maytag epic he has F6 code
The maytag statred making a loud noise this weekind on the spin cycle. TOday when it finished a cycle, the towels were still very wet. I tried the drain and spin a couple of times, then the F6 code came up.
    Scholar:
  • 87 Answers
What is the model number of this unit. Should be inside the door on the frame. If you take off the bottom panel, there is a tech sheet in there that will tell you what that means. I don't know that one off the top of my head and I can't get at my work P.C.right now. It'll give good detail of what to look for on that tech sheet Let me know if you have any questions.
Posted on Mar 06, 2009
Maytag neptune front loading washer
What is the model # of your machine???? The loud banging noise sounds like the loads were getting unbalanced. This is the most likely since i have no problems with the suspension all of a sudden not stabilizing tub properly. If the washer was moved or transported than that would make more sense to me. please provide as much info as you can. Try doing a load of 10 towels. Let me know how that does and with the model # i can help with pulling some diagnostic codes
Oct 02, 2007 | Maytag MAH6500 Neptune Front Loading...
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Noise when high speed spin cycle
maytag washer makes a noise when washing or spinning. sounds like a screw is stuck or maybe a bearing is going. It is getting worse each day.
Dec 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
First empty as much water you can thru the front door. There is the filter located right before the water exit pump. Remove the lower panel by unscrewing 3 screws underneath the panel, slide the panel out. You will see a 3 inch cap facing you. Either you must have a shop wet vac or a nice big plastic bag to collect the water which will leak out, there could be plenty. Clean out the filter, you may find coins too. You can pour some clean water into open machine to wash out the hoses. Replace the filter cap carefully, cover,screws.
You can rate me............
Mar 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Maytag EPIC MFW9700S Front Load Washer Logo
380 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
