Question about Maytag EPIC MFW9700S Front Load Washer
Maytag epic he has F6 code
Machine had started making a louder noise when spinning tis past weekend. The towels were still soaking when cycle finished. I tried the drain and spin, no luck. The next time I tried it F6 came up.
  • 1 more comment
  • Anonymous Mar 15, 2009
    Horrible noise when it tries to start the spinning, some noise also agitating counter-clock-wise. Drains OK when set to drain and spin, just soaking wet clothes. Not much play between inner and outer drum, and no noise when pushing down on inner drum and rotating by hand. So maybe the main tub bearing is OK (I hopoe), but the motor may be out. Having a technician look at it next week.
  • deeb5003 Mar 15, 2009
    Horrible noise when it tries to start the spinning, some noise also agitating counter-clock-wise. Drains OK when set to drain and spin, just soaking wet clothes. Not much play between inner and outer drum, and no noise when pushing down on inner drum and rotating by hand. So maybe the main tub bearing is OK (I hope), but the motor may be bad. Having a technician look at it next week.
    President:
  • 1,294 Answers
First empty as much water you can thru the front door. There is the filter located right before the water exit pump. Remove the lower panel by unscrewing 3 screws underneath the panel, slide the panel out. You will see a 3 inch cap facing you. Either you must have a shop wet vac or a nice big plastic bag to collect the water which will leak out, there could be plenty. Clean out the filter, you may find coins too. You can pour some clean water into open machine to wash out the hoses. Replace the filter cap carefully, cover,screws.
You can rate me............
Posted on Mar 06, 2009
I had to have the motor ($175.85) replaced (labor $140 for 2 visits, but really an easy DIY project). The reason was excessive play of the rotor on the axle. The axle is ribbed and the rotor has a similar ribbing, but there was not a tight fit - must be a manufacturing problem. The rotor was loose enough to on occasion grind against the front of the motor housing. The were grinding traces on the rotor and the housing and metal shavings inside. I found this by disassembling the motor, cutting the 4 silver screws with a bolt cutter (one srew has its threads filled to prevent taking it out). The motor was made in Italy. My washer was 1 1/2 years old but has only a 1 year warranty. Calls and a fax to Maytag did not result in any concession on their part -despite an obvious manufacturing defect. My advise: get the repairman out at the first little odd noise and don't buy any other white goods with only a 1-year warranty!
Posted on Apr 08, 2009
My maytag performa washing machine makes a winding motor noise when starting it starts spin cycle. Also has louder than normal noise while spinning and when cycle ends,
Sandra, washer may have a broken or faulty balancing spring. Have a good tech. diagnose and estimate repair. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 11, 2016 | Maytag Washing Machines
Maytag toploader Neptune washer stops with 10 minutes left on quick wash and code "uc" on LED. There is a little water left in bottom of tub and cloths are soaked. It does fine until the spin...
It sounds like the Outer Bearings are going due to a leaky Tub Seal. Bothe can be repaired and have done on this site. This site has no way to reference past post to machine issues.
I have helped owners of theFAV6800A and FAV9800A machines here but I prefer a tru DIY site.
I no longer post on this site no way to post a Sticky for machine issues.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The washing machine started making a grinding noise during wash cycle (minor) and a much louder grinding noise during the spin cycle. Is this a bearing? and is it replacable? Maytag MAV7600
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Jan 15, 2010 | Maytag MAV7600 Top Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
My Maytag epic he has F6 code
What is the model number of this unit. Should be inside the door on the frame. If you take off the bottom panel, there is a tech sheet in there that will tell you what that means. I don't know that one off the top of my head and I can't get at my work P.C.right now. It'll give good detail of what to look for on that tech sheet Let me know if you have any questions.
Mar 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Feb 03, 2009 | Kenmore 46462 Front Load Washer
Maytag washer wont start spin cycle...
INSPECT YOUR PUMP HUMMING NOISE USUALLY PUMP MOTOR ARE PRETTY RELAIBLE
Nov 29, 2008 | Maytag EPIC MFW9700S Front Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
