Question about Epson Stylus RX500 All-In-One InkJet Printer
My RX500 is not scanning?? Please Help??
After I've laid the picture in the scanning bed and done everything else right and have it on the "scan to PC" option and press the OK button nothing at all happens, but when I select the "scan to photo card option" it works. Please help, Thank You
    President:
  • 2,692 Answers
Black vertical line when copying a book page.no light leaks.
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
Nov 10, 2013 | Panasonic KXMB2030 AllInOne Printer
How do I scan transparancies? With the holder in place on the flat bed the whole frame scans and not the slide.
You need to put a piece of white paper, the same size as your slide on the back of your slide. Your scanner doesn't recognize the edges of the transparancy (it is looking through it), so if you place a white paper on top of your transparancy it wil recognize the edges.
Nov 15, 2011 | Epson Stylus RX500 All-In-One InkJet...
When i try to scan 35mm slides, all i get is a big black rectangle.
hi there!
make sure that you put the picture (the item you're scanning) on the right side of the scan bed, try scanning other sizes of pictures too, if that dont work, ive posted the link for that printer here, check out the manuals and troubleshooting steps too, they're all for free. you can also contact 800-HP invent or 800-474-6836.
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=446436&
Apr 06, 2011 | HP Scanjet 4890
Heya i'm stuck on how to scan my picture on a canon smartbase mp370 and want some advise on how to do it please thanks donna
Hai Donna.
If you have Canon Solution Center (I have HP Solution Center for HP printer, the name could be various) in your dekstop after installing the driver, click the icon. Scan option usually there.
If you can't find the option you can scan manually via Microsoft Word document.
- Open Microsoft word
- Insert > Picture > From Scaner > Click
- Scan option will appear > Preview > set scan area > Click Scan > Wait until finish
- The picture will appear on your word sheet > Picture option > set in front of text
- Right click > Save as picture > choose the folder to save > Click Save
- DONE, you can open your picture file in the destined folder.
Hope this help and if helpful RATE please.
Feb 02, 2011 | Office Equipment & Supplies
How to scan pictures with scaner?
place the picture you intend scanning onto the scanner bed with the top of the picture alligning ith the top of the bed.then press the scan button,the picture is immediately transported to your PC.here you can edit the pictue before saving it .
Jun 28, 2010 | Samsung SCX 4200 All-In-One Laser Printer
How do I scan in more than one page to a file? I would like to scan a 5 page document into one file. Can this be done?
You don't list the make and model of scanner, but if it's the type that comes with an automated document feeder, the software usually supports scanning multiple pages. If not, and you are planning to save it as a PDF, you can use Adobe Acrobat's "Scan to PDF" option--I believe it asks you after every scan if you want to combine that page into the same document.
Apr 01, 2010 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus Photo RX500.
hi there.. seems, a hard job huh? transfering it from 1 folder to other.
try this , open epson scan program, goto home mode. click preview, click scan, it will open file save settings window where you can select where to save your picture, under location , look for the folder where you want to save it, if its not on the list, select other then look for the folder or for your appleworks, once you found it, click ok, it will scan and save directly to the appleworks.
i hope this one works for your.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Feb 06, 2010 | Epson Stylus RX500 All-In-One InkJet...
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
My scanner will not scan negatives
Most scanners aren't designed to scan negatives. (Of course the manufactures would never want to tell you their product CANT do something).
Flatbed scanners typically have a light on one side.
To scan negatives properly, you need to have a scanner that has a backlight, or a second light in the bed's lid that you fold down.
Canon USA, Inc. make a few flatbed scanners that have backlights. They range from $60 to $180, depending on the features and resolution you want to pay for.
Please see the below link. This is a more expensive one, but is shown just so you get the idea. In the pictures, note specifically in the picture that shows the lid open, how the white backing on the lid can be removed from a clip at the top. Underneath, is the backlight and clips designed to hold negatives in with the included frames.
http://www.newegg.com/Product/Product.aspx?Item=N82E16838111015
May 04, 2009 | Epson Perfection V200 Flatbed Scanner
No picture, scans coming out white
First reinstall drivers , If problem not solved go to ur provider to repair your scanner . Thank You.
Aug 13, 2007 | Microtek SCANMAKER I900 Flatbed Scanner
Epson Stylus RX500 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
