Question about Philips Audio Players & Recorders
I held down the back button
And when i did it just says the device can perform faster and when i go to repair it it doesnt it says somehting about the firmware but i have everything updated
  • 1 more comment
  • apolamalofan Mar 07, 2009
    its not a go gear its a Magnavox 2B MSA2025 MP3 player
    ok i uninstalled the device manager from the cd and installed the one from the website its doing the same thing the only thing that comes up on the device manager is the repair option it says "a error has been reported on your device" the i repair it that doesnt work.The only time i can the the update option is when the MP3 player doesnt appear on the device manager and my computer still doesnt recognize the mp3 player even when the device manager does
  • apolamalofan Mar 08, 2009
    helped a little but got it to work
I did the updates and it erased all my information on the device including all the programing. Is there a way to reload the go gear programing?
Posted on Jan 20, 2010
  • 8,596 Answers
If it says "your firmware is up to date," then you are good to go.
If it says, "Firmware cannot be updated," then you are still good to go.
The device performance window is a Windows-related function that will do nothing whatsoever to spped up your Philips Go Gear.
The back button triggerred the Repair function. As long as you don't have a problem with your player, then you are fine. If you were trying to repair your GoGear, and it said "Failed to Update Firmware," then either: a)you are not connected to the internet, or b) your Go Gear is toast and needs to be repalced. Call Philips and fins out if you are still in warranty.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
  • Corey Knoettgen
    Corey Knoettgen Mar 07, 2009
    Aha! A Magnavox - you can still go to Philips' website, since they are the same company, or you can go to www.m4c.magnavox.com
    Enter your model #
    Go to the page for your model
    Click on Software & Drivers - get the latest "Device/Firmware Manager"
    Install and open the new Philips/Magnavox Device Manager that you have just downloaded
    Click on the "Update" button (will only appear if your player is connected to PC)
    Update the firmware
    The Philips and Magnavox players have a weird characteristic - in order to get a firmware update, you can't use the version of the Device Manager that came with the CD - you have to update the device manager first.
    If you had simply said the part about "your device can perform..." blah blah blah - I would've thought that you plugged it into a USB port that was weaker than a USB 2.0 port (this is especially common with laptops). But, since you mentioned firmware, I would go ahead and update the firmware.
    -Tha Mp3 Doctor
ASUS ZENPAD 102300C AFTER CHARGING GOES BACK TO RESET
Have you checked for firmware updates? You can try to do a hard reset which can force OS errors to clear up.
First method:
  1. In order to switch off the device, hold down the Power button for a short while.
  2. In the next step press and hold Volume Up + Power key at the same time for a few seconds.
  3. You can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Factory Reset", and press Power button to confirm.
  5. Success! The hard reset has just been performed.
Second method:
  1. Turn on the device by using the Power button.
  2. Afterwards go to Settings and then to Backup & Reset.
  3. Tap Factory Data Reset and select Reset Device.
  4. If it's necessary enter the safety code and choose Erase Everything
  5. Select OK to confirm the whole operation.
  6. Well done! After a while your tablet should be ready to use.
Third method:
  1. At the beginning press the Power key to turn off your device.
  2. Afterwards press and hold Volume Up + Power simultaneously for about 5 seconds.
  3. you can release held keys when you see menu on your screen.
  4. Then press Volume Down to select option "Recovery", and press Power button to confirm.
  5. Press Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
  6. Select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
  7. To restart the tablet, select "reboot system now".
  8. Success! The hard reset is done!
A Hard Reset will erase all of your data
Feb 16, 2017 | ASUS Computers & Internet
Doesnt turn on correctly
Soft Reset
To force the device to restart without wiping any data, simply press and hold the Power button for about 10 to 20 seconds until the device turns off. You should then be allowed to turn the device back on as normal.
Hard Reset Using Buttons
Note: A hard reset deletes data. Before performing these steps, be sure to backup your data if you wish. Some data can be backed up under Settings > Privacy > Back up my data and data that syncs with Google should re-sync once you have performed the reset as long as you use the same account.
1. With the Galaxy Note powered off, press and hold the Volume Up, Volume Down and Power buttons.
2. When you see the Samsung logo appear, release the Power button, but continue to hold Volume Up and Volume Down.
3. Release all buttons when the System Recovery screen appears.
3. Toggle the selection to highlight wipe data / factory reset using the Volume Down button.
4. Press the Power button to choose the selection.
Jan 24, 2013 | Samsung Galaxy Note 10.1 Wifi 10.1-inch...
EVERYTHINGH STARTED WITH A CHECK ENGINE LIGHT WENT TO THE MECHANIC AND SIAD THE IDLE AIR CONTROL MOTOR BURN THE COMPUTER .I HAD THE ECU REPAIR AND THE IACV REPLACE IT RUN FINE FOR A WEEK BUT NOW I...
Get the code pulled. I would say it is somehting else unless you the ecm that was rebuilt was no done well. try not to be down. try to think it will be somehting else. get the code and check back.
Jul 11, 2011 | 2001 Nissan Maxima
My Galaxy S will not turn on after the power button was accidently held too long by someone. What can I do?
Alright what you need to do is hold the power button and the Up or Down VOLUME button If it doesnt turn on try taking out the battery If that doesnt work try charger it If that doesnt work try replacing the battery or last option take it to a repair shop and see what they can do.
May 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
On turning my 6200 on the gps location is showing i am in york which is 107 miles from were i actually am ?? why is this and can i fix it
Try this resetting procedure:
1) Switch the unit OFF with that switch on the button (the one that needs the pen).
2) Now hold the power button on the top with your finger, and switch that switch on the bottom back to ON while keeping your finger held down on that button.
3) Something roughly called the Aragorn Boot Loader will appear and will count down from 5.
4) Release your finger off the power button on the top before it reaches 0 or you will have to start again.
This should have performed a hard reset, and you should be asked to calibrate the touchscreen.
May 14, 2011 | Evesham GPS
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
My rcam4204-a will not turn on /i have held the on button down for at least a minute or two with no response/when i plug into comp/it says please connect your device /even thou it is connected
You might want to try doing a firmware reinstall.
You can download the firmware update here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the directions to perform the install. If there is any media on your device you don't want to lose, be sure to back it up before you do the firmware reinstall.
Oct 17, 2009 | RCA M4204 MP3 Player
Ibm thinkpad a31p 2654
OK to begin your computer doesnt have 2.0 usb, its just windows is telling you about the device attached, I am not sure about upgrading it, but I doubt it is possible. Now from the error you posted, your computer did detect something. Are all the neccesarry drivers installed? If so I would take a look at your bios and set your PCI/Perriphrial to auto, sometimes that will resolve any port assignments which are somewhat commen in laptops, being as they use a hub
Jan 28, 2008 | Computers & Internet
Craig mp3 player
Reset the Device
NOTE: THIS IS AN ADVANCED OPERATION. NORMAL USERS ARE NOT RECOMMENDED TO PERFORM THIS OPERATION!
Sansa e200 provides a Reset Function. Please note that you only need to use this function if the device does not respond for several minutes. The button is like a power down button of the device. You can turn off the device by using a reset operation, such as pressing and holding the Menu button for 15 seconds. Once you perform the reset function, the adjustments you made during last
30
Dec 27, 2007 | Philips GoGear HDD6330 MP3 Player
PDA is totally black; not charging
The easiest solutions are easily overlooked. 1. Check your charger; a cheap multimeter will do for the voltage check. If the voltage (dc) written on the back of the charger is what you get at the plug, go to (2),if not, change your charger,problem solved. 2.You either have a messed up screen or battery. 3. Check the voltage at your battery terminals after charging the battery for like 1hr. If you do not get a resonable read; 2-5v ,just trash the battery and head for the nearest shop to get a fresh one.In case your battery reads okay,your screen or worse, one of the components on the board of the set has gone kaput.
Nov 14, 2006 | Palm Zire 71 Handheld
273 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
