Question about Gateway MX6453 Notebook
I want to buy a bigger HD but I don't know if my pc is capable of
Is there any way to upgrade the hd of my pc?? I heard that my MX6453 only supports 160 gb HD..
  • Gateway Master
  • 4,338 Answers
If yopur laptop can handle a 160 GB. Then it should be able to handle a 250 GB.
See this page:
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch3&model_id=60379
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 06, 2009
Hello, I have a Sony KV-36XBR450 36" TV, and heard that it was "HD" ready but needed an upgrade. at this point I would like to know it that upgrade is still available and if so does, does...
Your KV36XBR450 is HD ready which means that you will need a set top box to receive the HD signal. Comcast will provide this for you naturally at an additional expense. Your other option would be to purchase a set top box and use and OTA (over the air) antenna which will allow you to receive your local broadcasts in HD.
I am sorry, however i have no heard about upgrade for this set. There is nothing available even with Sony.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 27, 2010 | Sony KV-36XBR450 36" TV
How do I replace the hard drive on a Dell Latitude d610?
mostally on bottem acces for hd open with 4 screws and take out the drive and replace it for a bigger or for the same look out by buying hd for the same hight and idee or sata
Sep 28, 2009 | Dell Latitude D600 Notebook
HOW CAN I UPGRADE MY SYSTEM
it depends on how big the ram and the hd is. the bigger the hd and ram the more expensive it is except for their transfer rates. if your planning on upgrading because of games, you will need atleast 7200 rpm for the hardisk which costs more than a typical one. but for all i know thats the default for a desktop. there are 10,000 rpm also which are more expensive than the bigger hd's. same with the RAM. you can check ebay for the price. but the price depends on the country you are in if your buying it from your place.
Feb 06, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
New 250gb hd for inspiron 6000, not recognizing os
Make sure your memory is securely installed. please check
Personally i don't believe you needed the bigger hard drive.
Restart and go into bios setup once in set to default settings
then f10 to save and exit.
Let me know what happens
Dec 19, 2008 | Dell Inspiron 6000 Notebook
Hard Disk Upgrade
I don't know if you can call this a solution but I hope this points you in the right direction...
I personally trust WD over Seagate. Their external drives work like a dream. As for the size you wish to go with, well that is up to you. It really depends on how much you are willing to spend. Sometimes its cheaper to get the bigger size than to get the smaller one and spend more when you fill up what you have. I managed to buy a 500GB HD from Fry's for $130. Before I stray away from the issue, I would choose a WD drive, 320 over 250 GB, and I would get a friend who knows a thing or two about removing a hd from a computer so you can take it with you (just to make sure you get set up with a hd that is compatible).
Other factors that you may run into are RPM speeds. I believe they are 5400 and 7200. The faster it is then the faster things load. I also believe that the faster it is, the hotter it will get and the more power it will require. If you are concerned with getting a bigger hd then stick with what you know works, that being a 5400 rpm drive.
If you are really picky about things, I suggest going to cnet.com and reading reviews on the hd's before buying. Their reviews are very useful, they list user reviews, will compare prices with other vendors who sell the hd being reviewed and tell you if its priced according to performance or overpriced compared to similar models.
Hope that helps...
Dec 15, 2008 | HP Pavilion ze2000 Notebook
Can i upgrade to hd on this tv
I am not finding anything on the net about being able to upgrade it but the HD in the model # stands for high def but the tv is old enough that it may not go up as high as 1080 most likely just 480i or p which can be achieved with an s-video or might be 720 with the R/B/G connector or a DVI connector, you can look for converting cables on ebay
Jan 26, 2008 | Akai PT4298HD Rear Projection Television
Aiptek - Video and sound is out of sync
Are you recording in High Def? When I tried that on mine the same thing happened. That definitely has to be played back on Hi Def TV and the computer probably isn't capable of handling that. Switch to DVD mode, or Web cam mode and you won't have a problem.
Dec 03, 2007 | Aiptek A-HD 720P Flash Media Camcorder
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Gateway MX6453 Notebook Logo
27 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
