I would perform a test use of the spring before purchasing it to reach this conclusion. You can call ahead to several part stores that you've identified to carry the spring and request if test use is possible. Then, work with the stores that say "yes". Thank you.
To replace you need to locate the second spring on the other side of the dishwasher and remove it. The front base plate needs to be removed first to get access to the spring anchor points. Use a screw driver or a nose plier to grab it and dislodge. Always make sure the door is shut to ensure least tension in the springs. Put the two new springs and close the base plate. MAINS POWER CHORD SHOULD BE TAKEN OUT FROM SOCKET WHEN WORKING ON THE DISHWASHER
I can understand your frustration. Try this website https://plweb.evenflo.com/replacement_parts.aspx You would have to find out the model of the exersaucer you are using. There is also a number on this site that you might be able to call for assistance or for them to send you another manual. Let me know if you have any luck.
Yes, you need a spring compressor. The sturt and coil spring come off as one. Then you need to compress spring to remove strut. The old one off and the new one on and then un-compress the spring and remount in car.
Sounds simple, but it can take a while.
Check thier website. You can enter in the model # and date of production (seat ring that the cloth attaches to). From there it'll show you all the available parts for purchase. You can also find/buy replacement or "switch a roo" toys from their website. I found this by googling "replacement parts for evenflo excersaucer".
put the bottom and top togather where the 3 holes are on top put the springs put the caps on and turn them. You will have to use a little pressure but they will turn
need 3springs for exersaucer
