Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Control panel access
How do I access the control panel to get to the thermal fuse Kenmore ulta wash quiet guard
  • 188 Answers
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Posted on Mar 06, 2009
How do I shut my panel off for my kenmore presicion dishwasher with quiet guard
First turn off the child-lock or control-lock function. Usually this is done by holding down a particular key 3 to 5 second. The key to press is usually marked, but in very tiny (or light-gray) print.
Sep 16, 2014 | Kenmore Dishwashers
Getting no power to Kenmore Quiet Guard 587-16163401
Of course, theck the power supply the dishwasher is plugged into. The next place to check is the junction box on the bottom of the dishwasher, behind the toe kick panel. If everything is okay there, then it is probably the thermal fuse located inside the door, attached to the dishwasher controller. If you need a new thermal fuse, you can check SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Aug 16, 2012 | Kenmore Dishwashers
Where is thermal fuse
If your Kenmore dryer has stopped producing heat, chances are the problem lies with the dryer's thermal fuse. A fire-prevention safety device, the thermal fuse is designed to disrupt the flow of electricity to the dryer's heating mechanisms if the dryer temperature reaches a predetermined maximum. Once activated, the thermal fuse must be replaced to restore the heat to your dryer. In Kenmore brand residential dryers, the thermal fuse will be located in one of two places.
Instructions
Front Panel Access
1 Unplug your Kenmore dryer from its power source. Make sure that the appliance is unplugged before proceeding.
2 Use a flathead screwdriver or putty knife to remove the dryer's bottom service panel, sometimes called the toe panel. Slide the screwdriver or putty knife along the top of the toe panel until you've located the toe panel clips. The clips are usually located about four inches in from either side of the service panel. Push down on the toe clips with the screwdriver or putty knife to release. Remove the panel and set it aside.
3 Locate the thermal fuse on your Kenmore dryer. Look for the thermal fuse directly above the dryer's motor; it looks like a white strip with two wires, and is usually mounted off to one side. See Resources for a diagram of thermal components.
Rear Access
4 Disconnect the Kenmore dryer from its power source while locating the thermal fuse.
5 Move the dryer away from the wall so that you can access the back of the appliance.
6 Use a screwdriver to remove the dryer's back panel. Set the panel and loose screws aside until you are ready to replace them.
7 Locate your Kenmore dryer's thermal fuse just above the exhaust port. The thermal fuse looks like a white strip with two connected wires.
Tips & Warnings
Clogged exhaust ports are a common cause of thermal fuse failure. While you've got your Kenmore dryer in pieces, clean out the exhaust ducts to keep it functioning at its best.
Take all proper safety precautions when working with electrical appliances. Make sure that your Kenmore dryer is unplugged before attempting to service it.
Check this link ,if you use Whirlpool Dryers:
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/thermalfuse-dryer-Whirlpool-29inch-electric.html
Thanks
Apr 01, 2012 | Dryers
Have kenmore quiet partner 1 dishwasher. Fuse failed a year ago after 1 year in service, panel has no lights, suspect fuse again. Need to know fuse location and description of fuse
You didn't list model number. remove screws on inside of door to have access to controls. There should be a thermal fuse square object with two wires attached. Some brands now come with short pigtail wires, so bad terminals are eliminated. IF it's a kenmore, then go to www.searspartsdirect.com You can see parts diagram there.
Aug 05, 2010 | Kenmore 24 in. 16222 Built-in Dishwasher
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
My 2006 kenmore elite dryer wont turn on
The F40 code indicates a communication problem between the main machine control and the blower motor control board. According to your symptoms, it is likely that this problem is being caused by a blown thermal fuse. I recommend the thermal fuse for continuity.
Unplug the dryer before accessing this component. Access this fuse and pull one wire off. Measure the resistance across the leads of the fuse using a volt/ohm meter. You should measure near zero ohms of resistance (continuity) if the fuse is good. If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.
NOTE: If the thermal fuse is blown, check for a restriction in the exhaust vent to the outside of your home. This type of problem will cause the fuse to blow.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3390719.
This should fix your dryer problem.
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
How do I acess the control panel
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
455 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
