Question about Acer Aspire 5315 Notebook
5315 posted by kahmedkhi on Feb 28, 2009 I got Acer Aspire 5315. I am facing 2 problems. Code 39 and Code 28. Can anyone give me an advice for fixing up this problem. Thanks
  • 271 Answers
Code 28
The drivers for this device are not installed. (Code 28)
Recommended resolution
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
Code 39
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Cause
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Thanks
Posted on Mar 06, 2009
    President:
  • 1,257 Answers
Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on May 26, 2009
Can you give me the full software / driver of motherboard ? I want to format my ACer aspire 5315 .
To get the drivers for the Acer aspire 5315 just click HERE and download it.
Make sure you burn it in a disk and keep it safe.
If you face any problem the get back to me here.
All The Best.
With Regards:-
Subhankar Ghosh
Dec 11, 2010 | Acer Aspire 5315 Notebook
My acer aspire 5315 dvd rom doesnt work at all but somtime it do
There is a problem with the DVD ROM. Maybe it is not well fixed and causing conflict which result in making the computer slow. And maybe it is not contacting the system well again, that's why it worked and later not worked when it loose contact.
I would advice that you shut down your system, loose the DVD ROM and put the system back on without the DVD ROM after a little while when the windows must have settled, shut down the system again and fixed back the DVD ROM. Make sure it is well connected and put the system back on again. Test the DVD ROM and see if it would give the same problem. If it does, then may be you will have to replace the DVD ROM.
One a DVD ROM is bad, another one needs to be purchased, because it is usually difficult to repair DVD ROM expect in minor case.
I wish you the best.
Dec 18, 2009 | Acer Aspire 5315 Notebook
Cracked lcd sct reen acer aspire 5315 model
I would start by doing a search on Ebay. Often times you can get parts or a damaged laptop with parts for a very reasonable price. I just did a search for your laptop model and found a damaged Acer Aspire 5315 for $81. As of this posting on 10/31 at 9:10 am CST time, the auction ends in 2 hrs.
After doing a quick internet search, I found a web site called http://www.screencountry.com and I saw a monitor for your model listed at $99.
Oct 31, 2009 | Acer Aspire 5315 Notebook
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
You can get the drivers from the link below.Although it shows as Vista, it is also compatible with XP. Give it a try and let me know if it works
http://support.acer-euro.com/drivers/notebook/as_5315.html
Mar 06, 2009 | Acer Aspire 5315 Notebook
Aspire 5315
First things first - let's have you download, install and scan your machine for spyware/malware with Malware Bytes to make sure there is no malicious code running on your PC (a high enough percentage of the time this can be the issue).
Beyond that I would need additional info on how much ram you have in the machine and the operating system you are running before I could give you more definitive hardware advice...
Post the results of your scan/clean and any additional info back here.
Mar 01, 2009 | Acer Computers & Internet
this is a software issue with the SP3 installation. It can be fixed by formating your harddrive and reinstalling the operating system you are currently using. Or you can use VISTA.
Feb 28, 2009 | Acer Aspire 5315 Notebook
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5315 Notebook Logo
174 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
