Question about Poulan Pro Chain Saw 46cc 20"
Poulan 2800 chain sastarts and runs for about 2 minutes and quits
Poulan 2800 starts and runs only 1 or 2 minutes and acts like it ran out of gas. Plenty of gas in the tank. I changed fuel pickup (filter). No change.Repair shop worked on it and adjusted the carburetor which made it hard to start and still ran only 1 or 2 minutes before quitting. It worked fine prior to this this problem but started when I took it out to use it after running it earlier in the week with no problem. I also tried adjusting the carburetor. It started better but still only ran 1 or 2 minutes before quitting. After running 1 or 2 minutes, it will start again with some difficulty but then runs only 10 or 15 seconds before quitting.
  • fentj Mar 10, 2009
    Poulan 2800 chain saw runs good for 1 or 2 minutes and then acts like it is running out of gas. After that it might restart and run only a few seonds. Tried new fuel filter and checked tubing. Problem started all of a sudden with no pre warning.
    Novelist:
  • 110 Answers
Good evening and welcome to fixya. i will tell you im not an expert on chainsaws by any stretch but have worked on many. i will try to assist you the best that i can here i do have alot of small engine exp. a question for you once it dies after the 1-2 minutes of running is it hard to start? could be the choke getting stuck. also does your model have the primer ball that you must pump? if so i have seen a lot of those develops small leaks in them which is just enough to allow your equipment to lose its prime. you can check these if you haven't already and let me know, im sure we can get you all figured out. thank you
Posted on Mar 10, 2009
  • 94 Answers
There is a rubber diaphram in the carburetor that goes bad every so often. i would suggest buying a rebuild kit for the carburetor
  • 158 Answers
Hell, the gas cap has a vent and it sounds like it is plugged up with maybe saw dust or dirt. Take the cap off pull the inside apart it should separate. When you get it apart blow it out. Then reinstall you should be good to go. Thank you
Posted on Mar 06, 2009
    Scholar:
  • 165 Answers
The fuel pipe is cloogged and needs internal cleaning to solve the problem.
My new poulan will start and run great for about 5-10 minutes then will just quit running. let it set and cool down and it will do the same thing why?
important to use correct oil and mix. no guessing. too much oil mix fouls up the engine. make sure blade is adjusted properly and not gummed up with oily debri
Feb 14, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP4218AV 18" Chain Saw
Sounds loike its running lean, start by replacing the fuel filter on the end of the pipe in the fuel tank, if this does not help you need to richen up the mixture screws, unfortunayly you need a special toll to adjust the screws ( they have a spline, not a screwdriver slot ) the tool is part no. 530035560, once you have the tool unscrew the carb screws 1/2 turn on each and try again.
Feb 13, 2011 | Poulan PP4218AV 18" Chain Saw
Poulan 2050 14 inch chainsaw . Problem is ,it wont start. Has been good saw. Seldom used.while idling it quit running.so I went to refuel and noticed, it was not out of fuel.I pulled fuel filter to clean...
Same same for me as well ..need to rebuild a small engine
sorta fun on a small engine you can do it at kitchen table with your wife playinf solitare OR get a tV table and rebuild it on the porch
poor start scalled port good catch on your part to notice scorch
Jun 16, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Doesn't want to start. Replace carb and ran for few seconds, Make you think that it is not getting gas, but pouring gas into spark plug does not help and drying spark plug dose not help. Spark appears...
The spark should be blue and snappy. Try a new plug--any help? If not, it may need a new ignition module. Check the flywheel magnets--they should be quite strong. The module gap with the magnets underneath the poles should be about business card thickness. Check the air cleaner and muffler for plugging. Hope this gets it running!
Apr 07, 2010 | Poulan 1630 16" Chain Saw
I have a Poulan 2450 chain saw which runs great for awhile and then won't run or start. I checked for spark on the plug and none there. A week went by and I checked it again and now it works. So I...
It does happen they quit when hot. More often they just quit.
There are 7 different "2450 Gas Saw Types" here: (Type 1 $25.35)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
There is a help link on top that will eventually find someone with a pulse. If you go this way please have your saw within easy reach before calling. HTH
Lou
Good for you on the spark test and isolation of the problem. You also listed the make and model. I think I'm in love, LOL.
Thanks, it makes our help easy.
Oct 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Have craftsman chain saw, runs ok for a few minutes then dies. found broken gas line.replaced fuel line,air filter,spark plug, checked muffler, also mixed fresh gas.eng acts like its out of gas. leave it...
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Oct 04, 2009 | Garden
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 2375 w/18 inch bar keeps throwing the chain
when you put the chain on new did you adjust the tension on the chain.most new chains need to be ran a few minutes to heat them up a little.then you need to readjust chian so it doesn't sag out of the bottem of the bar,also when you adjust the chain you need to push the tip of the bar down so the bar is in the up possition.if you don't the bar will work it's way up and loosen the chain.
Feb 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw wont start after running out of gas?
Hi
Fill the gas tank with new fuel.Priming the engine(put some gas in the sparkplug hole for few times and start the engine until it runs constantly):There is small amount of water in the gas.
best regards savumihai71
Dec 27, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
192 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
