Question about Malber WD1000 Front Load Washer/Dryer
Leaking Using Malber WD1000 front load for 10 years, start to leak on the bottom in the front, any solutions?
  • ec89 Mar 12, 2009
    Thank you very much for the solution, it works.
  • Anonymous Apr 19, 2009
    The cleanup trap of malber wd 1000 is leaking profusely as soon as start the machine. I have cleaned the black seal but it doesn't work. Any solution?
  • 29 Answers
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Posted on Mar 11, 2009
Malber 1000 started leaking from the bottom. Water is coming from underneath the machine in the area behind the filter area
Usually what I have found is a small hole in the drain hose or coin trap, sometimes mice chew them and sometimes It is an abrasion wear from the balance brick rubbing. pretty easy fix though.
May 06, 2011 | Malber WD1000 Front Load Washer/Dryer
Water leaks (spewing) from sides of bottom of machine when it's filling up
The normal cause of leaking while it is filling is a leaking Inlet hose. Try pulling the washing machine away from the wall and watch the hoses as the machine fills. If it is leaking you can see which hose is leaking. You may either need new tighner clips or to replace the hoses depending on how bad they are leaking. Another possibility is the water pump inside the washing machine could be broken and spewing out water.
Aug 31, 2007 | Malber WD1000 Front Load Washer/Dryer
Water in drum after turning off
could be a leaking fill valve ..not shutting off good after shutoff
Dec 08, 2008 | Malber WD1000 Front Load Washer/Dryer
I have a Malber WD 1000 and need to replace leaking drain hose.
The malberusa website has a phone number for New York. Try there. I think the office is in Garden City, LI
Good luck.
Nov 17, 2008 | Malber WD1000 Front Load Washer/Dryer
Flooding
I never had this problem with my unit, but I've been using detergent that is specifically designated for front-load washers. You can find it at Target or any other store. It's supposed to reduce the amount of suds/foam build-up within the unit, so it might prevent thte flooding.
Hope this helps.
Aug 11, 2008 | Malber WD1000 Front Load Washer/Dryer
Drum does not spin
I had similar problem recently. It turned out the main controller right above the drain hose exit on the back was the problem. I got a new board from MALBER and replaced it myself. It is working now.
May 25, 2008 | Malber WD1000 Front Load Washer/Dryer
Loose Wheel and Leak
1 no just take the nut off and put a lock washer ingetween it
2 your using to much detergent
May 04, 2008 | Malber WD1000 Front Load Washer/Dryer
Leaking pressure hose
if the pressure hose is leaking replace it
Apr 23, 2008 | Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Leaking front gasket
Try to call 800-600-8913, they gave couple of number to call
Nov 07, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
347 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
