Question about Kyocera Mita FS 1000+N Laser Printer
How to clear paper jam at the back of Kyocera Mita FS 1000+. Paper stuck up in the middle, with dark shade on top of page. Is this printer capable of 2-sided printing?
  • 622 Answers
If paper is stuck in the back... then you have to take the machine apart... its messy but its just how it is... as for two sided printing... I would call kyocera support... they could best advize you on that... and they are quite friendly...
Posted on Dec 24, 2009
  • 27 Answers
Have you tried removing the imaging unit out from the front and pulling it back ?Be careful not to tear the paper inside otherwise you will need to call a technician to remove it from the fuser unit at the back side of it, and no it does not print on both sides.
Posted on Mar 13, 2009
I keep getting the message that there is a paper jam in my Kyocera Mita fs-1900 printer and I do not see anything
Download the user manual from the manufactures website, I provided the link below. Jam removal instructions start on page 4-12. If you follow the instruction and the printer still indicates a jam then you may have a bad switch or a switch that is stuck down.
I hope this is helpful,
Feb 15, 2011 | Kyocera KM-F650 Plain Paper Laser Fax
Paper Jam at back od Kyocera. How do i clear this?
The link below will take you to the manufature website where you can download the operators guide. On page 4-12 it explains how to remove jams from the printer to include pitures.
Feb 12, 2011 | Kyocera Mita FS-1920 Laser Printer
I have a continous red light (paper jam) on a kyocera Mita fs 1000+ not obvious paper jam,..... what's wrong?
If you are not seeing any paper there you most likely have a bad paper detect sensor. The paper detect sensor is what looks for the proper timing of the paper moving through the machine and indicates a jam when the paper stops.
Dec 24, 2010 | Kyocera Mita FS-1020D Laser Printer
Kyocera fs-1920 paper jams when page is half way out of top , when you clear it the paper has some grooves in ? does not happen every time and when cleared it is ok again for 3-6 pages
on the menu buttons on the machine..change the paper exit to go out the back.. if this solves the problem.. you might be looking into replacing exit rollers or fuser
Mar 09, 2010 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-1020D process unit in two pieces
best thing todo is get a new PU-102, the gap between the drum and dv unit is to large and the toner is not transfering.
Dec 27, 2009 | Kyocera Mita FS-1020D Laser Printer
Hi there i have fs kyocera 1000 and when i wont to print the printer tak the paper but the paper get empty and the printer stop .so i open the cover and close the printer resuom printing and the paper get...
clean the paper feed roller with a damp cloth after removing the paper tray, otherwise call a technician since parts may need to be replaced, including the roller in case.
Feb 26, 2009 | Kyocera Mita FS 1000+N Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Paper Jam?
add toner or image unit waste toner full check page count. check switch in duplex section same one for the fuser exit.
Apr 30, 2008 | Kyocera Mita FS-1030D Laser Printer
Grey shades coming all over the page as well in top back side of paper.
The Developer unit needs to be replaced. It gives background over entire page. If the printer is under 3 years old and is original unit (developer unit) you can get a new one free from Kyocera. Very good warr. from them. Phone number is 1 800438 6482 prompt 2 ; # for the part DV-62. Have your serial # and a status page with you. I work on Kyocera FS printers. Good luck. Russ
Dec 31, 2007 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS 1000+N Laser Printer Logo
796 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
