Question about Bosch 11222EVSG 1 1/8 Inch Grounded Sds Rotary Hammer
Bosch 11222EVSG hammer drill not turning
I have a Bosch 11222EVSG hammer drill, it hammers ok, but the bit doesn't
turn, and it gets stuck in the hole it hammers in concrete. Don't know what to
do. Appreciate any tips.
  • 2,176 Answers
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Posted on Mar 07, 2009
Chuck stuck open on my psb700 re
not much can be done as the chuck is not specifically designed to handle hammer drill operations (they crack the scroll thread adjuster inside )
best get a new chuck and if you do a lot of hammering get a proper hammer drill that has a push in operation not an ordinary electrical drill with a hammer capability
Sep 09, 2016 | Bosch Drills
Bosch hammer/drill 11222EVSG
turn knob clockwise till it stops. push button in with a screwdriver and turn it clockwise a bit more then it will wiggle out.
Jan 23, 2014 | Drills
Broken drill bit stuck inside drill
if you open chuck all the way the drill bit should just fall out
Dec 11, 2013 | Bosch 13624 24V Cordless Hammer Drills
I have a hitiachi DH38ye drill and it won't accept the Bosch spline bits. they go in ok but the chuck won't lock. The drill accepts the hammer bits fine but won't accept the drill bits
you have me stumped on this one. The tool you have is a spline shank hammer and it should accept all standard spline bits and also hammer iron that is made for these. Is it possible that the Bosch bit has a burr on the splines not allowing it to lock? I have checked the Hitachi site and found no reason it would not work. I will continue checking though.
Apr 23, 2011 | Hitachi Drills
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Bosch - Rotary Hammer Model 11232EVS
This site does not have the manual for the exact model number you are seeking but several that are similar and may be helpful:
http://powertool.manualsonline.com/ex/thread/view/idThread/76898
Sep 03, 2009 | Tools & Hardware - Others
My drill bit doesn't remain secure in the chuck of my drill.
grind bits shank in a triangle to let the drill chuck get a better hold of bit but be carfule because this also takes away the drills ability to slip if it hits something solid.
Apr 13, 2009 | Drills
Bosch 11222EVSG 1 1/8 Inch Grounded Sds Rotary Hammer Logo
223 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
