Question about Aprilaire 550 Humidifier
I blew out my 2nd selinoid just now - Aprilaire 550 Humidifier
    Problem Solver:
  • 8 Answers
Check and make sure the voltage is the correct - Usually 24 volts.
Almost every time one of these went out on me the wires were touching some part of the metal, or pinched somewhere. The easiest way to fix that is use a temporary wire and hook it up. Make sure you double check the voltage though. If you have a meter and know how to use it check for continuity between the wires for the humidifier
Posted on Mar 06, 2009
Hot tub makes a humming sound when you turn on the jets
Blower motor went out and blew fuse. You will have to replace the blower motor.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
Keep blowing 24V transformers
Somewhere in the mess you have described there is a short that is compelling the transformer to put out more current than what it is designed for. It gets hot, really overheats, insulation melts, and the wires melt. Ergo blown transformer.Problem is with whatever that unit is plugged into/powering..
Mar 03, 2017 | Aprilaire 400 Humidifier
My aprilaire 700 isn't coming on (no water flow). The front part of the unit has fallen off the furnace twice (held on by plastic nubs/slots...) and blew the furnace fuse/ and circuit breaker probably...
Check for voltaged at the solenoid valve. This will either be a 24 volt or 110 volt solenoid valve. Confirm power into the unit 110 volts. If you have power into the unit and no voltaged at the solenoid valve on a call for humidification at the humidistat than the circuit board or the step down transfgormer has failed.. If you do have voltage at the solenid valve than the valve has failed.
Jan 26, 2011 | Aprilaire 700 Humidifier
Wired a new 360 through Hum blew 3amp fuse. How to wire so it doesn't blow fuse. Have open EAC and EAC2.
Review figures 5, 6 and 7 on the installation instructions and compare with how you wired your installation.
The red wires are not used if you use a mechanical humidistat, (are used with electronic humidstat - supplies 24 volts and go to "hot", "commod" on humidstat). Yellow wired to "Hum" whether electronic or mechanical humidistat used.
If using sail switch or current sensing relay, cuts into one of the yellow wires. - One yellow goes directly to humidisat, then comes out of other side of humidistat & runs to to relay (or sail switch), and comes out of relay (or sail switch) and runs back to humidifier.
Dec 17, 2010 | Honeywell HE360A1027 Whole House...
I have water flowing thru the selinoid, the supply hose is clear, the final fitting into the drip spout is clear, but there is almost no water coming out of it and into the 6 hole tray that drips into the...
I have the exact same problem. I can hear the solenoid "click" but when I try and "blow" threw it I cannot. I removed the little screen filter inside where the copper pipe connects, still no luck. Not sure what the flat blade screw is for with the locking nut, other than to adjust the position of the solenoid. I checked for flow of water outside of the valve. Also my contractor hooked this up to the Hot water side of the water heater. Does anyone know if this is correct? I would think you get more corrosion on this side.
Dec 07, 2010 | Honeywell HE365 Humidifier
My 550 is bone dry. I've cleaned the small in line screen blew out the line. How do I know if its the selinoid or humidistat?
Turn off the water to the humidifier
Disconnect the water line to the inlet water valve (the solenoid), catch any excess water or drips in a small container
Turn the water back on slowly and see if water flows through the open line (the one you just disconnected - catch the water in a small bucket)
If you have water to the valve, it's probably the solenoid valve - you can test this by reconnecting the water line and turning the humidistat all the way up. You should hear a click as the solenoid tries to open. If it clicks and no water comes out it's the valve. If there is no water to the valve, you'll need to determine the reason(s). Although not every water valve has one, check for a plugged inlet screen at the entry to the water valve (solenoid)
Sometimes the small line tap valves commonly used with humidifiers can plug up or malfunction. If you try to repair or replace the tap valve, make sure the water is turned off.
If no click, it could be the humidistat or there is no power to the unit.
If the humidistat is bad, you won't hear any click and no power will be sent to the solenoid valve. In that case, the humidistat may be defective.
Depending on your comfort level and knowledge, you can try applying power directly to the valve by bypassing the humidistat, but only try this if you are comfortable working with electricity. The voltage should be around 24 volts (in the USA) , which is low, but requires some knowledge.
Dec 29, 2009 | Aprilaire 550 Humidifier
I need technical instructions explaining how the Holmes HM1865P works. I am doing a research project for a college class, and need written technical instructions as part of the project. This product is a...
to get the instructions. you can go to www.jardenstore.com . click on the holmes on the main page. in the search bar on the left type in your model the hm1865. click on the unit which should be the 2nd picture. right below that picture it has the manual. it will download in adobe reader.
Mar 04, 2009 | Rival Humidifiers
Honeywell TrueSteam Humidifier - I have 2 - one keeps flushing
don't know if this will help or not but dip switch 1 and 2 control the flush cycle on this unit. double check how they are set. the setting for flushing every 5 hours is not listed in the manual, but if both 1 and 2 are in the on position it will flush every 5 hours. hope this helps.
Jan 28, 2009 | Honeywell Power Humidifier: Furnace...
Power humidifier not operating when 2nd stage heat
If the installer used a #50 relay when they installed it they did not take in consideration the the fan will run at two different speeds in heating. Remove the #50 relay from the blower wire it is connected to. Reinstall it on the blowers white wire (neutral). This should fix the problem.
Good luck
Jan 26, 2009 | Aprilaire 600 Humidifier
Aprilaire 550 Humidifier Logo
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
