Question about Intel Computers & Internet
If their fair coins are tossed,find the probabaility that 1)one tail 2)2 heads 3)atleast 3 head
  • 2,692 Answers
Th odds on the next toss and evert toss will always be 50/50. Odds do not chance due to  previous results.If you toss 1,00o times and get heads every time the offgs on the next toss would stil be 50/50.
Posted on Mar 06, 2009
Where is the crankshaft position sensor on a 2004 isuzu rodeo 3.5
2004 no vin code posted nor the 8th VIN digit for engine code
so answers get 10x harder, lacking that one fact. USA car?
Coin toss 1:
learn the real name of engine, first
6vE1, 4 cams, and last year has VVT, (not trivial that)
and has 2 Cam sensors. to make VVT happy,. dig?
weve answered this many times here, over and over
did the scan tool tell you its bad.?
its on the rear of both heads,
the post above is wrong, he shows the 6vd1w engine,
here just for fun, again i post all V6,s just for you, and others too lazy to search or learn engine REAL NAME.
ill do all 3 V6 engines now.
Mar 18, 2017 | Isuzu Cars & Trucks
Latitude. How can I replace control arm and ball joint assembly?
Lower you can do fairly easy. Upper, a bit tougher.For the upper you will need a spring compressor.
Mar 21, 2016 | 2011 Jeep Patriot
What is the Head Bolt Torque on 1996 Isuzu
what engines.
not posting the engine option, makes all answers a guess.
33% chance. toss a 3 sided coin..
May 30, 2015 | 1996 Isuzu Hombre
Can a loose gas cap cause starting problems
loose , never!
wow, no year, nor any engines stated, you do make this hard.....!!!
wrong cap or stuck vacuum breaker can in fact stall a car.
any car with EVAP systems, 1980s to now.
Ever get a tuneup this DECADE?
why guess. why not post the full symptoms and get expert free help.
does engine crank fast???? yes/no
i toss coin , yes.
does car start with throttle held wide open , (super secret magic unflood mode) does it want to start now. or almost, see black smoke t tail of car?
toss coin, 2, no.
got spark?, using the STD 100 year old spark test>?
got spark to all cylinders. NO
does it get spark with 1 person cranking, and 2nd looking?
or does it get spark for 3 seconds then ends>? cranking?
or you look at ASD relay, 2 persons again and see that the ASD relay never pulls in?
ASD 101:
ASD is a feature,. it's your friend to stop Crash and burn.
Oct 17, 2014 | Jeep Grand Cherokee Cars & Trucks
Where is the coolant temp sensor on a suzuki grand vitara
If it's a 2.0 it'll be on the back of the cylinder head on the intake side, sort of between the engine and the firewall - it is a single unit with two separate and independent sensors, one for the dash guage, the other for the ECU.
Aug 26, 2012 | Suzuki Grand Vitara Cars & Trucks
Where is the probability button?
The EL-535 can generate random numbers for you. Press 2nd Function, 7. You will see random written above 7 in orange. This will give you four choices for random numbers. 0:RAND - random decimals to 3 decimal places 1:R-DICE -1 to 6 like a standard dice, 2:R-COIN - 0 or 1 and you decide which is heads or tails.3:R-INT for integers up to 99
Dec 06, 2010 | Sharp ELW535 Calculator
I'm using the application that simulates tossing a coin a certain amount of time and graphs the frequency that heads and tails come up. I need to make a histogram from it; how can I export/transfer the...
If you are using the ProbSim application to toss a coin, the histogram is drawn after each set of tosses.
  1. Toss a certain number of times using the +10 or +50 tabs.
  2. To export the data (a big word for just two numbers) stop tossing the coins by pressing the key under the tab [ESC] (the Y= key).
  3. The bottom of the screen will display 5 tabs :[ESC], [TOSS], SET],[DATA], and [TABL].
  4. Press [F5] to activate the [TABL] menu.
  5. Your screen will display a table with 3 columns: TOSS for the toss number, 1 for the result of the toss (Head or Tail), and the last column CumH the cumulative number of Head results.
  6. At the bottom right of the screen you have a menu [GRAPH] above the GRAPH key.
  7. Press the Graph key to execute the Menu graph.
  8. The histogram is drawn.
Aug 24, 2010 | Texas Instruments TI-84 Plus Calculator
Computers & Internet Logo
537 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
