Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
How do I acess the control panel
I am trying to get to the thermal fuse on a kenmore ultra wash quiet guard
  • 188 Answers
Open the door and remove the top screws connected to the console. Close the door (not locked) and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Posted on Mar 06, 2009
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Getting no power to Kenmore Quiet Guard 587-16163401
Of course, theck the power supply the dishwasher is plugged into. The next place to check is the junction box on the bottom of the dishwasher, behind the toe kick panel. If everything is okay there, then it is probably the thermal fuse located inside the door, attached to the dishwasher controller. If you need a new thermal fuse, you can check SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Aug 16, 2012 | Kenmore Dishwashers
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Mar 28, 2012 | Kenmore Dishwashers
Could you please help diagnose problem...dishwasher consistently stops washing in the middle of wash/sensing cycle. 2005 Kenmore Ultra Wash Quiet Guard 3
most likely the water is not hot enough,,it trying to heat the water,,when it starts to sense open the door and just test the water,,careful may be hot ,,but i doubt it...another easy way to tell is what is your hot water heater set on,,if you have a lot of soap residue is a good sign..
Sep 02, 2011 | Kenmore Dishwashers
My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Dishwaser does not fill
Hi. You can test the fill valve for voltage. If it is getting 120V and n water is coming in, change the valve.
Some models you can pull the float out.
When you lift it up and down, can you hear it clicking?
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Control panel access
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Mar 06, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
696 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
