Question about Maytag MSD2756G Side by Side Refrigerator
MAYTAG PLUS, MOD MZD2766GE STOPPED COOLING ON THE RIGHT SIDE,
STILL COOLING ON THE FREEZER SIDE. SPENT $280.00 TO FIX, THEY REPLACED A CIRCUIT BOARD AND SAID TO GIVE IT 24 HOURS TO RESET ITSELF, ITS BEEN 35 HOURS AND IS STILL NOT COOLING THE RIGHT SIDE STORAGE AREA.
  • Anonymous Mar 21, 2009
    Freezer works but right side is not cooling as cold as it use to.. Unable to store meat on right side as it spoils.. Freezer is packed full!!
  • gszasz Mar 21, 2009
    The compressor sounds like its working but the freezer cannot freeze ice cream and the refrigeraor is lukewarm.
    I tried the light panel defrost suggestion and nothing changed.
  • 410 Answers
After they replaced the part did they defrost the unit. there is probably ice build up on the coil behind the service panel in the freezer compartment. If the defrost control was the part replaced you can probably push the refrigerator side light switch in and out 5-6 times and force a defrost. if the unit goes into defrost then all the components are fine and you just need to manually defrost the coil either by off loading all food and leaving the unit off for 4-6 hours with doors open. of offloading freezer side remove rear access cover in freezer exosing evaporator coils and use a hairdryer to defrost the ice accumulation. good luck Peyton
Posted on Mar 06, 2009
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
Maytag MZD2766GE refrigerator side is not cooling well. Freezer side has no problem. Where are the coils for cleaning? Any other ideas?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Maytag MZD2766GES Side by Side...
Mzd2766ge Maytag refrigerator not cooling but freezer is ok. this happened before and it was the defrost circuit board. where is this board located? Do you think a new board will fix the problem and where...
Hi, Most sites have an exploded view that shows where it is located...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 19, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Ice is forming on the bottom of the freezer side of my MAYTAG MZD2766GE SIDE BY SIDE and water is leaking out of the bottom onto the floor. This happened before and the repair guy said it was a drain...
unplug unit and let sit overnight, the return air ducts are icing up, if you help the defrost process it will take a couple of hours, use your hairdryer to blow warm air in the freezer compartment for a couple of hours , good luck
Nov 07, 2009 | Maytag MZD2766GES Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
539 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
