Question about Garden
I have a 1995 26'' 2 stage 9hp Yardman track type electric start snow thrower. The fan or I guess it would be the second stage and at full throttle does not appear to be turning very fast and throwing even light snow very far. I just changed the two belts that drive the fan and auger with no apparent increase in speed. Any help in this manner would be greatly appreciated. Sincerely, Jay
  • 205 Answers
The impeller is held on the shaft with roll pins, perhaps they have sheared off. try to turn the impeller by hand (with engine off) if it turns and nothing else does, look for some cross holes there should be 1 or 2. A good hardware store will have replacements. Use a punch with a blunt end to knock out the pieces that are left, and take them for sizing the replacements. Good luck CB
Posted on Mar 17, 2009
WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE SNOW BLOWER VS A DUAL OR MULTI STAGE SNOW THROWER
Single stage has one rotating blade that collects and exhausts via upper shoot.
26373343-4yt0j151ox44pteg2g1nkeph-2-0.jpg Two stage has one blade for gathering into the center and a second that exhausts via shoot.
The two stage works best!!
26373343-4yt0j151ox44pteg2g1nkeph-2-5.jpg Hope this helps?
Nov 26, 2016 | Garden
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
How can I adjust the throttle on my Toro Snow thrower?
There are a couple of reasons this could be happening.
1 - Check the top of the throttle shaft where the shaft meets the plate, if it is loose or separated it will not allow the throttle plate to move properly.
2 - The governor spool may be damaged internally in the engine.
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
http://www.barrettsmallengine.com/manual/tecumsehcarburetormanual.pdf
Feb 03, 2016 | Garden
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
What is a snow blower?
A snow blower gets rid of snow. There are one stage blowers (called snow throwers) that just throw the snow away. There are also two stage blowers that have one stage where the snow is put into the machine and then a second stage where the snow is blown away.
Jan 16, 2013 | Garden
I have a Craftsman 22" Auger type snow thrower with electric start thatwill not start. It had gas in it from last winter. I primed it , I set the choke to full, gas open all the way and, at first, it
if you are using ethanol the check the gas lines for a plug because the ethanol leaves a residue behind that can plug your gas line.
Dec 29, 2012 | Garden
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
