Question about Radio Communications
I need software to reprogram my TK3130 Kenwood radios. They have a custom set of parameters in them and I want to reset them to factory defaults. The software I'm told that I need is KPG 75. Any ideas where I might get it.
  • greg24650 May 06, 2009
    I have the same problem. I also need the software to program the radio.
    Problem Solver:
  • 13 Answers
The software and cable for this model was not made available to the public. We offer a service to reprogram the kenwood TK 3130 radios for $25.
Please contact: support@hitechwireless.com
Posted on May 06, 2009
How do i reset a kenwood tk3160 to the default settings.
SUPER ODD...
I scoured your KENWOOD TK3160 Users Manual and a RESET process is NOT shown at all!? Find the link below...
They DO mention Programming Software and THAT may be your BEST solution?
You also want to gracefully reprogram your transceiver and SOFTWARE is your best choice for that too!
Your programming cable is about $5.35 FOR TWO on eBay... I KNOW!...
Anthony
http://manual.kenwood.com/en_contents/attachDownload/1000011002
2xUSB Programming Cable Adapter for Kenwood TK 3102 TK 3107 TK 3118 TK...
Dec 02, 2017 | Kenwood Radio Communications
Kenwood TS-2000 Power up fails
You will likely have to do a reset on the radio. The method to do this is hard to find in the manual. I have inserted it below. It usually works for me. Doing a full reset will reset EVERYTHING. It is essentially a last ditch attempt to get the radio going again. I hope this helps
PARTIAL RESET
Perform a Partial Reset if a key or control does not
function according to the instructions in this manual.
The following data is NOT erased by performing a
Partial Reset.
• Memory channel data
• Menu settings
• Antenna tuner preset data
• ANT 1/ANT 2 data.
Reset the transceiver by pressing [A/B]+ POWER
ON.
• "HELLO" appears on the display.
FULL RESET
Perform a Full Reset if you want to erase all the data
in all the memory channels. In addition, this function
resets all the settings that you customized, to the
factory defaults (i.e.- menu settings, antenna tuner
preset data, etc.).
Reset the transceiver by pressing [A=B]+ POWER
ON.
A confirmation message appears when performing
the Full Reset. Press the [A=B] key to proceed.
Otherwise, press any other key to cancel the Full
Reset and return to normal operation.
When you perform the full reset:
• All frequencies, modes, memory data and AT
preset data are set to the factory default values
(refer to "INITIAL SETTINGS", above).
Nov 24, 2016 | Kenwood TS-2000
How to reprogram a kenwood tk3000 read/write protected.password forgoten
Typically, you need to take a radio with a password to a dealer who has the Factory software. They can get past a password issue using their Kenwood software.
Nov 01, 2015 | Kenwood Tk-2000 Tk-3000 Vhf Uhf 5w Radio...
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
Hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
Feb 09, 2010 | Yamaha RX-V1000 Receiver
I set the Ip address manually to 192.168.1.0 and now I can not connect to the media vault and/or the control center
That is not a valid IP address.
IP addresses must end with .1 to .254
I am surprised that it let you set it to zero
Best bet is to reset the media vault to factory defaults and then follow the manual to set it up. Go to support.hp.com for more info.
If this helps, please vote for my solution.
Oct 03, 2009 | HP 1TB HP Media Vault Pro mv5140
Progamming software for kenwood tk-270g
kpg56d is the software you will need for that radio.
Also here is a link to the service manual
http://download.qrz.ru/pub/hamradio/schemes/kenwood/TK-260G_ser_man.pdf
Aug 18, 2009 | Computers & Internet
Radios will not trasmit
The Motorola T-6510 uses FRS-GMRS frequencies the TK-3130 uses 2 UHF frequencies. Unless you had the radio custom programmed to match the GMRS frequencies it will not work.
May 04, 2009 | Motorola Talkabout T5100 (14 Channels)...
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
Radio Communications Logo
202 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
