Question about JVC AV-27530 27" TV
Why is the color red is gone
No color red
  • 905 Answers
This is because of the color control circuit for the red , its most likely an IC that controls red has failed or even a bad resistor , capacitor , ect .. in that circuit will need replacing
Posted on Mar 06, 2009
I lost the color red on my computer
It sounds like you may have an issue with your power supply, graphics card, or monitor. You should call on a local professional to help properly diagnose the issue.
Jan 14, 2013 | Acer Aspire X1200 Desktop PC - Athlon X2...
Hello, my video card is nvidia geforce 6150 le and the red color is gone, thank you for your help.
You should be able to adjust the color balance for the card. There will be software on your machine that allows you to set the color balance and other things. Usually there is at least some red However if the red is totally gone then it could be a problem with the cabling/connector between the desktop and the monitor, like a loose pin or wire. It is possible that it may be the monitor that has the red out. So first check your connections and your color balance. If that seems ok then try another monitor before you go further. If a different monitor has the same problem (with different cabling too) then you will know.
Aug 16, 2011 | HP Compaq Presario SR2020NX PC Desktop
My E771 monitor colors suddenly shifted with
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
Check the red colour out put section at LCD base PCB..the capacitor is weak or the transistor is gone bad,replace with new one..
Jul 09, 2009 | Samsung PCL541R 54" Rear Projection...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
How to apply color to start menu and taskbar in windows vista
These little things can drive you let's go...Right click in an open area of your desktop-at the bottom of the box that opened- click on Properties then- Appearance tab- under Windows and Buttons- select -Windows Classic style. Now in the -Color scheme- select Rose or whatever color you like...then click on Apply and then OK.
I think you are missing the Apply and then OK.... this will do it for you, Enjoy your world of Roses..bye
Mar 21, 2009 | Dell Inspiron 1525 Laptop
My red is gone
there is color tracking problem in the tv. probably the tv is loosing the drive for one color, I will say the blue color
Aug 06, 2008 | JVC AV-27D303 27" TV
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
JVC AV-27530 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
