If car burning oil piston rings worns out also oil leaking by valve seals and valve guides.if car not smoking but you are losing oil check for oil leaks around oil filter or front timing cover where some oil pumps located if you have chevrolet engines some of 3.1 and 3.4 engines has oil pump drive gear large O ring under oil pump drive gear will crack crumble up cause massive oil leak.oil pump drive gear is located top engine where distributor use be located with engine running carefully look around all areas i told you should see fast oil drip.if engine smoking heavy blue engine is burning oil check one of spark plugs if inside spark plug electrode soak in oil engine is burning oil.
Year, make, model, engine size?
How does it run?
Do you see a lot of black smoke out the tailpipe when you accelerate?
do you see anything leaking?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: Burning over a quart of oil every two weeks
you more than likely have some bad rings.
Go to autozone and buy a bottle of Lucas oil treatment, and add it to the oil, if this does not solve the problem you will need an engine rebuild.
SOURCE: oil consuption
Sell the car! ;) i change valves and piston rings! nosing change, but good luck with trying!
