Question about Kenmore Elite 21086
The cold intake hose clogs with a green color like sand
I recently had a liscensed plumber add a laundry sink in my garage. since the installation, & rehooking up the water softner in which seems to be working, the cold side line from the washing machine's filter clogs with a flourescent green color like sand feeling gunk. i am having issues of understanding what is causing this?
  • 15,935 Answers
This is copper oxidation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Can i use my hotpoint first edition washing machine with just a cold water feed under sink it has a hot and cold feed but i only have a cold water feed under sink
you can of course but set the temp control to cold only . normal is not from under any sinks tho . have a plumber come and add a hot water outlet for you
Apr 28, 2015 | Hotpoint Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Maytag top loader washing machine. When it spins the water out about 2" comes up in the sink I have in the laundry room and then it immediately goes out. What could be wrong with it? It just...
You probably have a restriction in your drain down line of the sink-our sink does this because of the size of the discharge hose we run out to the garden to use the water for the garden-so you may want to have a plumber snake out your line-cheers Denny
Oct 24, 2013 | Indesit W 123 Front Load Washer
The kitchen sink faucet is clogged
If it just the hot or just the cold then it will be the shutoff valve not the faucet. replace the valve/s under the sink Try checking the screen in the head of the faucet for sand. If it does not have a screen(some dont) then it will have a restrictor usually green in color that may have debris inside of it.
Jan 06, 2013 | Kohler K-692-VS Clairette kitchen sink...
The hose detached from the garbage disposal. I re-attached it and now the water can't pump out of the bottom of the dishwasher
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Jul 08, 2012 | Whirlpool Dishwashers
Overflow draining to the sink
it's supposed to drain out the same drain pipe your sink uses. If it is overflowing into your sink, then your drain pipe is clogged. Your sink probably overflows when your disposal runs too, right? Unclog your pipe and you're good to go.
Jan 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Clogged sink after using garbage disposal
You have a clogged trap. Try a plunger, draino or disconnect the trap and clean it
Mar 15, 2009 | Home
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Washing Machines Logo
21 people viewed this question
Sal De
fordexpert
Robert Rankin
