Question about NetGear DG834G Router
How to configure the netgear modem?
I'm trying to set up a dsl connection and I'm using a diff modem as specified by the dsl company. They don't know how to configure it.
Hello
how to configure adsl modem router netgear dg834gt
Posted on Jul 06, 2009
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Netgear DG834G wireless router wth built-in modem doesn't connect
    Check if you have types all the configurations properly, namely Encapsulation / user name n password.
    Jun 21, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
    I am trying to use the usb adaptor with a compaq presario computer with windows XP, and a router that i got with AT&T. i remember it working once, but i cant remember how to set it up. everytime i...
    Te first thing you should do is remove all power from the AT&T devices (modem, router, etc) for at least ten minutes. This will do several important things.
    1. It will force your ISP (AT&T) to drop all connections to and from their router to the DSL modem.
    2. It will force your ISP (AT&T) to re-establish the connection to the DSL modem.
    3. It will force the DSL modem to clear all RAM and reload its default configuration when power is re-applied.
    4. It will force the wireless router to clear all RAM and reload its configuration information when power is restored.
    The 10 minutes is not arbitrary, some Motorola DSL modems supplied by AT&T have a specified 8 minute memory backup capability.
    Nov 25, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
    DSL connection not being shared by Linksys RV042 Dual Wan router
    Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
    1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
    2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
    Feb 24, 2009 | Linksys RV042 VPN Router
    How to add a netgear wgr614 router to dsl modem
    The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
    Jan 05, 2009 | NetGear WGR614 Router
    Problem in reconfiguring WGR614 v5 after reset
    You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
    Cheers !!
    Feb 24, 2008 | NetGear WGR614 Wireless Router
    NetGear DG834G Router Logo
    958 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
