Question about Poulan Pro Chain Saw 46cc 20"
How do i remove or change the clutch on my Poulan model 3314 chainsaw???
  • 97 Answers
Remove cover,chain,& bar. Hold crank and turn clutch counter clockwise to remove.Replace in reverse order.
Posted on Mar 14, 2009
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Show me how to change clutch on 3314 p
Use a Poulan clutch tool and look at the clutch for the direction to rotate the clutch. There will be an arrow and It should be CCW
Sep 14, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan 3816, back fires through carburator, wont start.
water in the gas or carb needs to be removed and taken apart and cleaned
Feb 20, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
What is the oil to gas ratio on Poulan 3314
Poulan and Poulan Pro chainsaws with 2-cycle engines require a 40:1 gas-to-oil ratio, which corresponds to 3.2 ounces of oil per gallon of gasoline.
Jun 15, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Chainsaw will start but will not keep running. Saw is new Poulan chainsaw model 3314
Is this unit under warranty? If so, take advantage. If it is out of warranty, did it work well up to this point? The carburetor is not pumping fuel, but running for a short time on the prime. Remove the carburetor and check the body screws for tightness. Make sure the pumper port to the crankcase is open. If it is a Walbro brand carburetor, remove the lower cover (4-screws) and make sure the diaphragm is next to the body with the pin side in, then the thick gasket, and finally the cover. Hope this helps.
Sep 01, 2009 | Garden
Poulan 3314 piston change, special tool needed???
Needle nose pliers. You would normally use a new lip when reinstalling it.
Mar 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Dec 10, 2008 | Poulan Garden
Poulan Pro Chain Saw 46cc 20" Logo
359 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
