Question about Shakespeare Surf Fishing Rod and Reel Combo
I do not know how to thread line through reel . No instruction on how to set up reel for fishing.
  • yankee09 Apr 12, 2009
    How do you get the line to feed into the reel it is threaded through the eyes, where do I attach it to the reel?
Put spool of string on a pencil and have someone hold it, now snake the string through the eyes of the pole and attach it to the reel, on the small shaft in the middle, then just reel your pole in untill you reach YOUR limit of string..
Posted on Mar 07, 2009
When I cast the line the spool unravel inside and tangles a guy I ran into says I need to set some stuff can you explain to me what I need to set
Pete, you are talking about a fishing reel correct? Check the attached links video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tips on Fishing with Spinning Reels
10 tips for proper reel care
Reel Maintenance Instructions
Which one to Choose Baitcast Spincast Spinning
Apr 11, 2016 | Fishing
How to take reel apart to reload line
Hi Karen:
If this is a fishing reel, pull off the old line into a plastic bag or wind it on to an old spool so it can be safely discarded. Tie the new line on to the reel, and wind the new line on.
There used to be a closed face spinning reel that you would unscrew the face cover to access the spool.
If this is a weed eater, grass whip, some of the older units had a threaded centre with a left hand thread. Once unscrewed, the spool lifted off and you could wind on the new cutting cord.
Happy fishing, or gardening.
May 14, 2015 | Sport & Outdoor - Others
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
What do you do with the line before threading it through the eyes
Take the line off the spool in such a way that the line will be caught by the bail after you cast the line. The easiest way to get it right is to raise the bail like you are going to cast the line, thread the eyes, then trip the bail with the handle, as though you were reeling 'em in.
Happy fishing. I'm jealous.
Best regards, --W/D--
Jul 20, 2009 | Shakespeare Surf Fishing Rod and Reel...
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
No instructions for how to feed line onto Penn fishing reel 500L
put line through ur spreader on the multi[plier then tie a loop not cut off the little bit after tying knot then wind up slowly till it starts to get tight then speed up ur process till u are happy with the amount on ur reel
Mar 01, 2009 | Penn Gt Levelwind Series Reels
How to reel in a fish
To reel out push on Z on the nunchuk and continue to rotate nunchuk or push on B and Z
Jan 12, 2009 | Nintendo Rapala''s Fishing Frenzy for Wii
Shakespeare Surf Fishing Rod and Reel Combo Logo
1,742 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
