Question about Sentry Fireproof Safe
I HAVE NEVER HAD A SAFE BEFOR . IT SAYS TO INSERT THE KEY IN THE KEY SLOT TO THE LEFT OF THE ELECTRONIC LOCK KEY PAD. I FEEL TOTALY LOST BUT I DON'T SEE ANYWHERE TO PUT THE KEY
  • 80 Answers
Http://www.sentrysafe.com
call them they will help you.
mj
Posted on Sep 07, 2009
Key loose / does not stick in ignition slot
Diagnosis: Basically, the ignition slot thinks the key is in so the lock mechanism is in place, which prevents the key fob from going in all the way.
Solution: Insert your finger all the way into the slot. Curl your finger slightly so that the tip touches the bottom. Pull your finger out slowly and your finger will "unlock" the mechanism. You will hear a click sound and also feel it being unlocked. Try inserting your key fob into the slot.
May 26, 2013 | 2009 Audi A4
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
Batteries are dead and I've lost the keys. Its an old electronic digital safe and I have the key number that goes with it. Know where I can get replacement keys or if its cheap enough to have...
Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
Please provide a rating for my help++++Thanks for using FIXYA
Jun 15, 2010 | Safe International Digital Electronic Safe...
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
Mar 06, 2010 | Sentry Fireproof Safe
I have lost our spare key - where can I buy a
HUBBIE LET SAFE BTTERIES RUN OUT THE LOST BOTH KEYS ( BOTH ON ONE KEY RING??? )
NEED KEYS FOR A ..
NUTOOL SF10 ELECTRONIC DIGITAL SAFE..
HELP NEED PASSPORTS!!!!!!
JOAN
Jan 31, 2010 | Safe International Digital Electronic Safe...
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
I forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
59 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
