Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is it and how do you replace it?
  • guybulliard Nov 03, 2011
    how do i fix it
  • 15,935 Answers
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Also
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
Also
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
Kenmore model #790-9642440A and getting a F30 alert.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks
Oct 04, 2011 | Kenmore 96422 / 96424 / 96429 Electric...
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore electric Range 2005
we are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
Nov 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
329 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
