Question about Emerson EWL20D6 Television
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE TV WORKS BUT THE DVD WONT COME OUT AND IT MAKES A WEIRD SOUND. WHAT CAN I DO? THE MOVIE JUST STARTS PLAYING AGAIN.
    Sergeant:
  • 239 Answers
Tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
Posted on Mar 06, 2009
Samsung dvd player - dvd stuck inside & cant get it out. Door will open but dvd tray wont come out. Sue
Posted on Apr 04, 2009
How do I hook up a dvd play to this TV
Connect the output leads of the DVD player to the corresponding inputs on the rear of "this" TV, whatever it may be.
Jan 10, 2017 | Televison & Video
Why can't I get the DVD player to work? I have it hooked up to a cable box.
im wondering why you did not connect it to the tv ?? but instead to cable box , does it have a pass thru capability ?? does it need to be off to pass thru ?? as most dvd player don't have a rf output but instead use a hdmi or composite signal output , would it not be easier to connect one of these to a spare input on tv then when u want to use dvd you only need to select the proper input from tvs source button to view the dvd ??
Jan 10, 2017 | Sylvania Televison & Video
I can't watch a movie from my Samsung DVD player it is hooked up to Bose and tv
Unless your dvd player is defective you have it wired incorrectly. Have someone else check what you did.
Jan 07, 2017 | Samsung Televison & Video
Can not play movies from my DVD player to my Bauhn TV model no 0916/atvu65
You have checked the cable? And does the DVD play on another machine?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 03, 2017 | Televison & Video
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
How do i watch my tv with a broken remote
You can buy a universal remote and program it to work with your TV. I have always had good luck with RCA universal remotes. You can also program the remote to run your cable/sat box and your DVD/blue ray player. You could also go to the web site of the company that made the TV and order a new remote. This would be more expensive but the remote would run all the funcitions while the universal may not.
May 24, 2014 | Televison & Video
DVD player wont eject dicks or play just say's disc error
You need to insert dicks into the DVD player, also, once it ejects the dicks, you should wait 20 minutes or so before attempting to eject more dicks.
Jun 26, 2012 | Televison & Video
Where can I purchase the Audio Video Connection for my dvd player I want to hook it up to my TV but can't find the correct cable Thank you Sandy
For the COBY TF-DVD7500, the video is carried on a single RCA plug cable. You can make due with a composite video cable (with three RCA plugs on each end) or get an RCA cable. The audio output can either be digital audio (which uses a special coax cable) or a headphone connector (analog audio).I believe the headphone jack is a 3.5 mm connector. If you use a composite video cable to your TV, you can connect the red and white plugs to an adapter (3.5 mm M to 2 RCA F). Then the TV speakers will get the audio track; otherwise you can use the DVD player speakers or the digital audio out.
I hope this helps.
Jan 24, 2011 | Coby TF-DVD7500 Portable DVD Player with...
Emerson EWL20D6 Television Logo
717 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
