Question about Samsung FPT5084 50 in. Plasma HDTV
Tv shuts off wont come backon samsung fpt5084x
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Posted on Apr 23, 2009
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
Samsung hlr5067w shuts of after 30 seconds... flashes red
I would suspect the lamp first as they can cause intermittent shut down issues.
Nov 03, 2009 | Samsung HLR5064W DLP Projection TV
I have a 50 inch Samsung, Model FPT5084X/XAA that won't turn on.
Do not bother replacing the whole power supply for just a few well known bad capacitors on it!
Just get quality ones (both better quality *and* higher breakdown voltage) and you won't have this problem ever again...well at least for sure not before a tons of other issues.
See here:
http://blog.coppelltvrepair.com/2013/07/samsung-fp-t5084xxaa-dead-no-response.html
and here:
http://www.coppelltvrepair.com/p/517/samsung-fp-t5084xxaa-power-supply-repair-kit-for-dead-or-shutting-down-board
Hope this helps!
Oct 20, 2009 | Samsung FPT5084 50 in. Plasma HDTV
My tv want come on ? i cut it off and it want come backon
Probably bad or leakey capacitors in the power supply. A good tech can replace the puffed up and leakey ones rather than replace the board.
Mar 09, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung 50in. flat screen lost all power
IF YOU HAVE NO LED STATUS, THEN IT'S THE POWER SUPPLY
Dec 23, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung FPT5084 50 in. Plasma HDTV Logo
1,043 people viewed this question
Jerry Greenberg
Jerry Greenberg
