Question about Epson Stylus CX9400 Photo Printer
I CHANGED THE INKS BUT MY EPSON CX4800 DOESN'T RECOGNIZE THE EPSON INK CARTRIDGES. THESE ARE THE ONES THAT I HAVE ALWAYS USED WHAT DO I DO
  •  Robert Allocca
    Robert Allocca May 11, 2010
    Please do not use Caps as it means you're SHOUTING.
    Problem Solver:
  • 7 Answers
1st: Make sure that the part numbers for the cartridges are correct.
2nd: Try taking them out one by one then place them back in, making sure that they'll click into place.
*Note: Just in case same issue persists, there is a possible issue with just the carts or the printer itself.
In case that happened, the best way to isolate the issue further is to try a different cartridge and if same issue then its the issue with the printer.
Posted on Mar 16, 2009
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Bought a Workforce 1100 Epson printer and it came with ink cartridges. Those worked fine but, once one of the inks ran out, I bought the whole series (at Costco) of all 5 inks and replaced the magenta. The...
if it is still under warranty , call for a technician to do a warranty check
there are some printer manufacturers that have an inbuilt program that will cut out the machine if anything but genuine cartridges are used
under warranty or not , there is a clause in consumer law that states , the unit has be be replaced or money refunded it the machine is not fit for the purpose or the unit fails before a reasonable of period of time in use
one round of cartridges is not a reasonable expectation of the time in use not is it fit for the purpose if it will not work after one round of cartridges
Mar 10, 2017 | Office Equipment & Supplies
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Jun 09, 2010 | Epson CX8400 All-In-One InkJet Printer
Skips many lines when p[rinting. We have cleaned nozzle changed all ink cartridges for new epson ones. Help!!!
The print head on Epson machines is built into the printer. The print heads are also not replaceable. It may take multiple cleaning cycles to clear it up, which may consume an entire set of ink cartridges to do. If you were using low quality compatible ink, the mixture of the inks can lead it to coagulating and really mess things up. That is why we only use high quality inks designed to match the OEM specs, not generic one type fits all inks. panderson@cartridgeworldusa.com with questions.
Jun 09, 2010 | Office Equipment & Supplies
Epson C90 failed to detect ink original cartridges
I guest, the problem is chip module attached on the head (housing). Need to be change
Hope could solve ur the problem
Rusdi
Mar 10, 2010 | Epson Office Equipment & Supplies
Enable epson stylus CX4800 to only recognize black cartfridge and not color ones
Did you use Epson Genuine Cartridges?
for the Color Ones?????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 28, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Using knockoff ink, Epson allows repalcement only
Please do not for a minute beleive that Epson endorses or allows the use of refilled ink cartridges or third party cartridges. It is just not true.
Consider this:
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 19, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Comments: I bought my printer( epson sx415) 2 weeks ago. It is my 3rd epson printer and I have always been happy with them. However I have the following problem. The first time I used it and inserted the...
woo really this is crazy. does the paper it prints on seem soaked in ink. i mean is it wet and all blurry and smudgy as if its using a tone of ink on the paper, have you tried lowering the settings, really there is no excuse for it using this much ink,. if i was you i would strait away bring it back to the shop you got it from with the recipts for all the ink and ask for another printer strait away and the money for the ink. what yeah think of that for an idea. really there is problem with printer its not sealing the cartage when not in use or its shooting to much ink at once. i think the main problem is its not sealing the cartage when not been used and its leaking the ink this is why u must clean each time because the inks drinking on the dripping cartgaes. hope this helps in some way.
Dec 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer cx4800
Inks aint Inks, buy epson cartridges and hope that the print head has survived the invasion, will probally need a few more cleans but with good ink. No Promise on survival.
Nov 09, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX9400 Photo Printer Logo
257 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
