Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
SONY Trinitron (POWER on. Black screen.)
Theres a light in power led indicator.No display on screen.
Does it have something to do with the flyback or just a component in the power supply board?
  • Sony Master
  • 19,396 Answers
This is not the flyback, if the model is the one listed in title, it has no flyback, has it is a rear projection. The motherboard is possible, but also C board and D board are likely.
If there is a flashing led on front of the TV, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, a convergence IC has blown, or a faulty on Digital board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check also connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact SonySony Global - "Contact Us".
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Mar 07, 2009
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Red LED Standby light blinks 5 times. TV will not turn on
This should be a scan failure indication. Usually its the flyback assembly, horizontal output transistor and a failure in the driver circuit, and or the power supply. It is possible the vertical amp could cause problems.
Your set will require shop service. The tech could troubleshoot for the fault and replace the defective parts. It may be of better value to replace the set.
Jerry G.
May 12, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-32FX68U problem, blinking power light
Please update this with the count of hte blinks. This is a diagnostic code that will indicate the problem circuit. From that we can tell you probable solutions and their costs.
Thanks,
Dan
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't power on
the flashes are a indication of the actual problem. 5 flashes along with a popping sound is the flyback transformer failing to provide the high voltage necessary to reproduce the image on the screen.
Jul 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Picture and sound problem at 21" sony waga color tv
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Doesn't turn on, but LED blinks 5 times
The flashing light is an indication of the sweep falure. Most of the time it is in the sweep output section, like the flyback transformer and or the horizontal output transistor. Most of the time it is the flyback that causes all the problems and componet blowouts in these sony TV sets, but it is also sometimes the vertical output IC that shorts out the sweep power supply. In any case a solid state set is no where to be experimenting around with and should only be worked on by a trained service tech. Good Luck
Oct 08, 2006 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
