How do I set up a network key, after we have already installed our Belkin wireless? And I believe we have thrown away the box that contained the disc..grrr
    Problem Solver:
  • 5 Answers
You wont need the disc - the default ip for a belkin i think is - simply tap this in to a browser (internet explorer) you will be asked for user and password (default is User: admin Pass: admin) from here you will be able to define any settings
Posted on Mar 06, 2009
Where do I find the Network Key (or WEP or WPA Key) number for my Belkin F5D8236 router?
Hello cyndi0417.
If you have installed your router, and have a computer connected to it through one of the wired ports, you can follow these steps to find your WEP or WPA key.
Step 1.
Open a web browser of your choice, and in the address bar type in "" (without the quotation marks).
Step 2.
Select "Login" from the upper right corner of the screen. Unless you have changed the administrator password, you can just click on the submit button.
Step 3.
Look under the "Wireless" heading on the left side of the page. There will be a selection for Security, which will contain the WEP or WPA settings. The numbers/letters in the boxes is your key.
Feb 01, 2011 | Belkin F5D8236-4 Router
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
I have a belkin wireless router it works fine but i dont know how to get the laptops to work as wireless, i also dont know how to change the password or any keys to get the other laptops to works, thanks...
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Aug 13, 2010 | Belkin Computers & Internet
Install router in to clearwire home box
If it is a wireless router with a Cable connection, first check the back of the router and find the "YELLOW" or In Port and run a cat 5 cable from the back of your cable modem to the "IN" port on the router. Next power the router up and provided you already have a wireless card in your computer, belkin usually is a browser based interface located at, Netgear routers most always are
Once into the interface it's not too difficult to set your paramaters, wep key and network name. Once you've named your network say MYHOMENETWORK or something like that your computer should be able to find and access the router and internet connection by you providing the same wep key as you entered while setting up the router an example of a wep key would be f9dbbb9462. Use the identical key when connection from your computer to the router.
Jul 22, 2010 | Belkin (F5D7230-4) Router (587009)
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
Sep 23, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Feb 18, 2009 | Belkin (F5D5231-4) Router
Belkin Wireless Router/HP Laptop - wireless security problem
This is an unusual problem. It's interesting that you can connect without encryption. A few thoughts, which you may well have considered already:
1) Does this happen even when you deliberately disconnect from the network, and reconnect?
2) The network key/passphrase is case sensitive; it is very easy to make a small slip with this, or some other tiny detail, when entering the key;
3) Is there the slightest chance your router has the same SSID (name) as a neighbour's? ....Sorry if this seems a daft question, but it is something to consider...
Nov 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My Xbox 360 Says No Wireless Network, 192.168 takes me to!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting PS3 via Belkin router to internet, wirelessly
Oct 28, 2007 | Computers & Internet
Belkin network adapter driver problem
this driver is constant problem, the best way to do it is to remove the driver and the adapter. re install the software, then connect the adapter to a different usb port and try again, or, connect the adapter and then when it asks for a driver point it to your cdrom where you have the driver disc and force it to install from there, once installed, open up the belkin manager console and dissable it and allow windows wireless zero configuration to run the adapter it is more stable
Oct 06, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
