Question about King Kooker 1209
King kooker will not burn a blue flame, only a big yellow sooty
I'm using a fully charged 20lb propane tank and when lit the flame is yellow, no matter how i adjust the air or the volume of gas, I can not get a steady blue flame.
  • 8,220 Answers
You may need to resize the orifice, sounds to me like it is too big. If you have an adjustable orifice try tightening it down a quarter turn at a time till that flame turn pretty. Leave that shutter wide open till you start getting a blue flame. Make sure you have no cob webs blocking the orifice.Blow out and remove all rust from the burner.
Posted on Mar 06, 2009
What color should the flame be on a propane fireplace insert---blue or yellow?
clean burn gas is a blue flame
it is achieved by using the correct jet size for the gas in use and by adjusting the air shroud around the jet opening
if you converted from natural gas to LPG and didn't change the jet size that is one reason
next there is a tin type shroud around the jet area that can be moved back or forward over the big hole that lets air to mix with the gas at the jet
the position of that shroud adjusts the air to gas ratio
If you are not sure of what I am talking about , talk with a gas fitter or have them do the job
Oct 10, 2016 | Napoleon Heating & Cooling
Way is my machine using to much propane
Are you smelling gas around the grill or tank? Fill a spray bottle with soapy water, slowly turn on the tank valve, and check for leaks at the tank valve, hose, regulator, as well as each gas valve (remove the knobs first). If no smell or leak is found, check your burners to see if they are burning mostly blue. If they are lazy yellow, they could be dirty or partially clogged and require cleaning; or possibly rusted through and need replaced.. If you do have blue flames, consider turning down the burners for a reduced flame and see if that helps.
Apr 30, 2015 | Grilling
Propane smell. When you light the oven and turn it off, the burner does not go completely off. Burns at a low yellow flame and sootie. Caused a co issue last night.
Probably a bad solenoid valve. Cut off the source before replacing the solenoid valve. Use caution, if you are not sure hire a professional.
Feb 28, 2015 | KitchenAid Kitchen Ranges
Does not start. manual start doesnt work either.
First, is your grill on a cart or built in to an island? Secondly, are you using a 20lb propane tank to fire the grill or is it hard piped to the grill from your house? And finally, has it been converted from Propane to Natural Gas?
If you're using a 20lb LP Grill Tank are you sure there's still gas in the tank? Did you just installed a new, full tank recently and the problem started after that?
If the latter is the case, turn off the grill tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY, until it's fully open. Light each burner one at a time and turn then to high flame. Do the flames look normal? Are they the proper height? Is so, you just solved your problem. Remember to turn the tank valve on very, very slowly after turning it off each time.
If you grill is hard piped from your house, be sure that the gas line shutoff valve is turned ON.
Hope this helps solve your problem.
Feb 15, 2011 | ProFire PF27G Grill
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
Tried to use my turkey fryer and could only get a yellow flame. Never had a problem getting that nice blue flame before. Do I have a reg problem or a burner prob??
Check your propane tank first; is it getting close to being empty? Check where the hose connects to the burner, there should be an air adjustment there; it looks like a rotating disc with two big holes on either side, this is turned when the burner is lit to adjust the amount of air mixing with the gas. If it's all the way open, you have a yellow flame, if it's closed all the way you have a blue (but weak) flame. Try adjusting that and if that doesn't work, try a different regulator...it is rare a regulator could cause this but it could cause it; just use that as your last resort.
Dec 03, 2009 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
Can a king kooker be converted to natural gas?
natural gas nozzles are sized diffrent than lp gas.not safe to convert.should consult manufacturer
Oct 10, 2009 | King Kooker 2992920 Propane Smoker
How to use propane tank?
leave the propane tank on and install a gas ball valve after the tank. you can see that the gas is on by the position of the valve,
Aug 16, 2008 | King Kooker Grilling
Inefficient (big, yellow flame) on wall propane heater, using up propane too fast
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
May 15, 2008 | Dayton Heating & Cooling
King Kooker 1209 Logo
744 people viewed this question
Top King Kooker Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a King Kooker Grilling Expert? Answer questions, earn points and help others
