Question about ASK Proxima DP1200x Multimedia Projector
Ask Proxima A1200EP won't turn off.
On the screen we see powering off but it just stays there forever. Finally unplugged the projector. Have several of these and it has happened with at least 3 different projectors.
  • 2,237 Answers
These projectors have a habit of overheating and causing main board problems. it may need upgrading.
Posted on Sep 03, 2009
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not power off
reset the unit,if the problem persists,contact your infocus dealer
May 28, 2010 | InFocus IN24 Multimedia Projector
Monitor keeps losing the screen and goes black several times before it finally stays on
it happened may b due to inproper power supply.So check the monitor data cable & other connections also.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
Replaced lamp now projecter will not turn on hd70
I had a similar situation, but we fixed it.  I can't exactly tell you why it worked nor whether or not it will for you.  Here's the deal.
First, take your lamp out and re-seat it.  This is one of the easiest ways to get a projector not to power up.
In our case, the thing would fire up, show us the Optoma logo, the blue screen, and then within about 15 seconds, it shut down, lamp fail light came on, and only a hard power reset would let us try again.  The bulb was good; after all, it came on, right?
So, we kept playing this game of power up, fail, unplug, replug.  I gave up and went to do something else.  I came back to the projector, needing it to let me see a screen to configure (weird I know, but that's how it was).  Anyhow, at this point, the projector stayed on, no problems.  So, I kept it running through the night with a kitchen timer on.  After 5 1/2 hours without failure, we knew we were set.
The point?  If it's powering up and showing picture for even a brief period, try cycling it several times.  However, if it's overheating or showing any other signs of distress, you may make it worse using my approach.  I think we may have just been lucky or the projector gnomes came in the night.
Jun 25, 2009 | Optoma HD70 DLP Projector
Projector problem
I had this happen too. Occasionally, you will press the power button, but it won't shut down, everything else seems to work. I was forced to unplug it a few times which is a bad deal. I finally traced it to some kind of strange power loop from my DVD player. If you have multiple sources, I'd try it for a while without them (one at a time) and see if you can isolate it, or better yet, if you have a way to swap them all out temporarily and add them back 1 at a time, you may be able to isolate it. It didn't seem to help to unplug or disconnect the DVD player before powering off the projector. It had to have never been connected. Took me quite a while to figure it out. It's pretty obscure, hope it helps.
Feb 17, 2009 | Sanyo PLV-Z2 Multimedia Projector
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
ASK Proxima DP1200x Multimedia Projector Logo
185 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
