Hello. my dishwasher is constantly pumping. i have checked the float underneath the machine and it is dry. any other clues?
Possibility is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
SOURCE: no fill - drain pump running - I assume stuck float switch
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
SOURCE: Neff dishwasher sticks on 1 minute
We had this problem with our machine.
There turned out to be a few things that caused it:
- Firstly, the float assembly (an orange looking float in a little chamber, visible if you take off the left-hand panel of the machine) was clogged - we cleaned this and it seemed to help.
- The heat exchanger matrix was full of debris - we tried to clean this but ended up damaging it and bought a new one.
.. these two things seemed to improve the cleaning and the machine worked for a while.
The real problem though (which caused it to pump out continuously) turned out to be a failed seal on the circulation pump.
If you look on page 4 of the following link:
https://www.neff-eshop.com/eshop/neff/gb/prodp.htm?eShopType=S&prod=S5456X3GB%2f22
.. you will see a diagram of the bottom of the machine - the part that failed was 171598, which you can see on the bottom middle-to-right hand side of the picture..
The rubber had perished very badly, and it was causing water to leak into the bottom of the machine, which triggers 'flood mode' whereby it pumps continuously and doesn't actually wash the dishes.
The part costs about £5 - fitting it is not straightforward though, as you need to strip the machine down which is a pretty involved job.
If you think you're up to it, the steps I followed were:
- Remove both side panels
- On the left hand side, remove heat exchanger matrix and float assembly
- Remove kick-panel under the front door
- On the right hand side, remove all wiring from the door to the machine (including an earthing wire which is screwed to the side of the machine) - note that there are two wires which go to push-on connectors which have to be removed separately - all the others go to connector blocks.
- Inside the machine, remove the wire baskets, spray arm and bottom filter.
- Remove the lid from the salt dispenser - and now the tricky part, you need to find something that will allow you to remove the large plastic 'nut' that holds the salt dispenser to the machine.
- Remove the two screws in the bottom of the machine (167241 in the diagram mentioned above)
- Now, shut the door and then disconnect the door spring mechanism from the left and right side of the door.
- Disconnect the string from the door closing mechanism from the springs at the left and right back corners, under the machine.
- Remove the two screws at the back of the machine which connect the top of the machine to the base.
- Remove the two screws at the front of the machine which connect the top of the machine to the base (these are quite low down, near the door hinges).
Now, you should be able to lift the top of the machine off the base, and will have access to the pump etc.
... re-assembly is the reverse of disassembly ;-)
This took me a couple of hours - it might be better to find somebody who will do it for you for fixed cost as it's a pig of a job.
For what it's worth, there seemed to be very few places where the machine could leak - and this looked to be the major one - and there are a few push-fit pipes which are worth checking out too.
Hope this helps somebody.
SOURCE: I have a Bosch Exxcel dishwasher which runs the
I am not sure about this model but most models run a drain cycle for a set period at the start of a wash cycle and then move on to normal filling and cycle of machine provided the various switches are at the low level it will carry on to its set cycle,is the apartment or flood switch ok?
SOURCE: my neff S5443X2 dishwasher pump keeps running - in
When this happens usually it is a sensor.and/or the main unit Brain. One needs to troubleshoot to tell, as many, most? symptoms seem similar but have differing sources. One needs to troubleshoot.
To have any chance at DIY repair you must obtain a service manual.
below is a DIY website to assist you in isolating your issue. If you cannot find a service manual (I looked but was unable to find one) then the best way would be to contact Neff direct, http://www.neff.co.uk/ and ask for one.Simply contact them and ask.
DIY website below.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
