Question about Samsung DLP HL-P5663W 56" TV
My 56 inch hi-def projection samsung tv turns off automatically
My samsung turns off by itself the red temp light comes on, i turn it back on it will stay for 10 minutes then it will shut off again?
  • 1,197 Answers
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Posted on Aug 31, 2010
    Samsung 56" Model HL56A650C1FXZA will
    Mine is doing the same... anyone find a solution?
    Jul 05, 2011 | Samsung HL56A650 56 in. TV
    When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
    Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
    Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
    The lamp will not turn on--replaced and still light--has a flashing red temp light on in front but can not be hot as lamp never comes on. Iss there a way to reset the temp light. thanks Bill
    hi if your tv starts for a few seconds and restart again and go
    back to stand by chances are that the problem
    is what is call the color wheel
    Sep 28, 2010 | Samsung DLP HL-P5663W 56" TV
    I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
    my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
    May 24, 2010 | Vivitek V37655 56" DLP TV
    Samsung 56in big screen lights flashing-cuts off
    theres defective caps in the power supply
    Apr 25, 2010 | Samsung Televison & Video
    My 56 inch tv shut itself off and will not turn back on, all 3 light lower right are blinking, any answers?
    You need to change the lamp. This tele doesn't have a color wheel so that leaves the lamp or the power board. Try the lamp first, it is the most likely problem.
    Jul 21, 2009 | Samsung HL-S5679W 56" HDTV
    TV won't come on ...
    These newer sets are haveing power supply problems the capasitors all go bad. If the tv is out of warrnty it will cost a lot to repair.
    Jul 09, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
    Sounds like maybe the convergence chips are shot
    Oct 06, 2007 | Zenith IQB56W10 56" Rear Projection...
    Samsung DLP HL-P5663W 56" TV Logo
    505 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
