Question about Ricoh Aficio 2018D All-In-One Laser Printer
Dont know how to configure scanner on Ricoh Africo 2018d. It is set up as a network printer atm
There are a few ways, such as configuring "SMB", "Scan to "Email" and/or installing "Scanrouter", but they are too involved to explain here.
The other is the "Network Twain Scanner" which, once installed, you can use a program such as "photoshop" , or many other photo editing softwares to scan. Simply open the program, click "file", "Import" and you should see the scanner as an option, make your settings, and go.
You can get the software here. Just select your operating system. It will need to be installed on each PC:
Posted on Mar 06, 2009
I used to be able to scan a lot of documents and then just last week I couldn't scan any document using the Ricoh Aficio Type 2018. The message "Sending has failed. Press Job Information key to check the...
It is a problem with the network connection, if you are using scan router recheck the configuration settings in case of scan to email check connection with smtp server, port no. ssl on or off and do the connection test, check mail server authentication, rest assured it is not a problem with the machine or GW controller.
Feb 18, 2015 | Ricoh Aficio 2018D All-In-One Laser...
How do I scan small documents with custom sizes with Ricoh 3025 Africo scanner
Look at page 107 of the user guide
Dec 23, 2014 | Ricoh Office Equipment & Supplies
Error 36851: No response from scanner" ricoh
Dear kishorkamble,
We fixed this error, which happened in another model (Aficio MP-5500), by configuring two options:
1. Activating SNMP protocol. Menu Configuration -> Network -> IPv4
2. Activating RSH/RCP protocol. Menu Configuration -> Network -> SNMP
I hope it may be useful.
Yours sincerely,
Bruno Coutinho
Feb 07, 2011 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh 2018D fuse unit
You probably won't find one new, the model is to old, used is your best bet.
Jun 01, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
I am having trouble scanning a document on the Ricoh Aficio 2018D, I also cannot locate the user manual, can you please advise how to scan on this machine?
If the scanner has not been configured, or network settings have changed, the setup for scanning on this unit is unfortunately quite difficult for a novice. the manuals are readily available at, under Downloads, but this will not help very much with the scanner config.
Dec 08, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Jul 02, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
2,783 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
