Question about Toshiba Satellite P105-S6227 Notebook
I have no sound on the speakers, it says there is no audio device
It seems to me I deleted some driver, but, the device manager says all instaled feature under sound and..are working properly
I have Harman Kardon HK206 Computer Speakers and my Father was deleting programs from our computer and didn't know that he deleted the program that reads our speakers so now we aren't getting...
The speakers do not require drivers. The software that has been deleted is for the sound card in the computer. Before you do anything on the computer, just double check that the speakers are connected to the correct socket - usually light green colour. Then check that the speakers work by connecting to another source e.g. MP3 player or Hi-Fi or TV. If the speakers are OK then check the PC output socket with other speakers or headphones.
To check the PC drivers, you need to first check that sound card drivers are installed and working.
Click on the START button. Then RIGHT-CLICK on My Computer, select MANAGE. Click on Device Manager in the Computer Management window. In the list that appears in the right-hand pane, click on the plus + sign next to Sound, video and game controllers. Check that no items have a yellow warnig sign and that various audio devices are listed. You should have at least AUDIO CODECS, LEGACY AUDIO DRIVERS, Manufacturer specific drivers (e.g. Realtek High Definition Audio). If the drivers are not there then you will need to re-install them, probably by downloading them. If any yellow warning signs are shown, then that driver is in error and may also need to be re-installed.
You can also try right-clicking on the driver in the list and select UNINSTALL. Then click on Action in the top menu and select Scan For Hardware Changes to try to re-install the drivers.
May 18, 2011 | Computers & Internet
Can i download the driver for micros innovations m600d computer speakers? I have deleted it
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 24, 2011 | Micro Innovations MM600D Computer Speakers
I can not get a sound in my computer
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 31, 2010 | Computers & Internet
I deleted my sanund device, how I fixet?
hope this helps
Dec 22, 2010 | Computers & Internet
Its been deleted
you might have to reinstall the souncard and its driver
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or
navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Dec 15, 2010 | Computers & Internet
I accidentally deleted the sound driver on my laptop. It's an HP Compaq tc4200 running XP. I tried downloading and installing another driver but it didn't work. How can I reinstall and get my sound back?...
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
hope this helps
Nov 29, 2010 | Audio Players & Recorders
I accidently deleted something that made my speakers and headphones stop working in control panel
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 22, 2010 | Altec Lansing ADA 215 Computer Speakers
I deleted my auio device .. there is no sound please help how do i install it again??
hope this helps
Nov 16, 2010 | Audio Players & Recorders
The speaker are plugged in but the computer does not seem to recognize that they are. It also says there is no audio device and no drivers are installed
Means windows cannot find your sound card and has not installed drivers for it. Thus no sound.
Need to reinstall sound card drivers.
First check if hardware / device manager shows error state for sound card. ie yellow circle with exclamation mark. If so delete those drivers and restart to reinstall. If you're lucky it will install correctly next time. Otherwise you need to install drivers yourselves from m/b or sound card driver CD
Apr 21, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
Toshiba Satellite P105-S6227 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
